Aluminum Intake Question
Old May 16, 2022 | 09:49 AM
67Rocket's Avatar
I have found an aluminum intake with cast plugs screwed into various outlets that have been in there for a long time, is if safe to use a impact wrench to back these plugs out? Thanks
Old May 16, 2022 | 10:38 AM
bccan's Avatar
Sounds like, a soak with penetrant, maybe a little heat (not a lot) around the opening and an impact gun will likely bang it right outta there. Hit it in reverse, if it doesn’t give way cleanly, add some more oil, retighten, back it off again. Back & forth between reverse/forward and it should come right out. I would not “zip” it out, gradual should ensure you don’t end up with any aluminum threads on the plug. Breakaway is your potential battle, after that should be nuthin.
Old May 16, 2022 | 02:03 PM
rickw30's Avatar
^ this..
penetrating oil, little heat on aluminum for expansion and EASY back and forth ( tight/loose) is the answer.
Old May 16, 2022 | 02:40 PM
I've never had good luck with an air impact on the those plugs, usually it just strips the hex out. Then you find yourself drilling and thread chasing.
Old May 17, 2022 | 04:55 AM
67Rocket's Avatar
Thanks, I am concerned about stripping threads.
Old May 17, 2022 | 05:07 AM
rickw30's Avatar
Remember, the key is go slow and EASY. Once you get it to break loose, use penetrating oil and go back and forth as if you were tapping a new thread.
Old May 17, 2022 | 05:21 AM
VC455's Avatar
Barely Registered
In 1970, I bought a 1965 Corvette FI setup for $50. And, as normal in south Texas, the car had been run with plain water--meaning that the fittings were stuck.
I repeatedly heated each with a propane torch and then applied oil. Most came out eventually with hand tools.
One was STUCK.
I took it to the plant where I worked and one of the maintenance guys my age took a small-tipped acetylene torch to it. He heated around the steel plug until well beyond the time I would have stopped for fear of melting the aluminum.
When he stopped heating, he quenched the plug with oil and easily turned it out with a hand tool.
It's still scary when I think about it! But I made that FI assembly a show-piece and it's now worth around $8000.
I'm not recommending this extreme, just explaining that heat on aluminum can do wonders. There is such a difference in expansion rate between steel and aluminum that the bond can't hold forever.
Old May 17, 2022 | 07:56 AM
oddball's Avatar
^^^ This. Proceed with caution. Heat and oil are your friends. Or just ignore them.
Oldsragger
May 17, 2022 04:46 PM
tpayne
Sep 26, 2013 06:25 PM
my442conv
Aug 22, 2011 12:34 AM
Kace
Aug 25, 2010 05:41 PM
77omega
May 10, 2008 09:47 AM
