aluminum intake with hei
Old March 10th, 2015, 05:34 AM
Dbechtel71's Avatar
Hello can anyone tell me if they make an aluminum intake that will take the hei distributor? Reason being I bought an hei and it won't fit in the edelbrock intake I have on my car. Thanks
Dbechtel71 is offline
Old March 10th, 2015, 06:42 AM
Which manifold are you running?
oldcutlass is online now
Old March 10th, 2015, 06:46 AM
Macadoo's Avatar
I'm using the Edel 3711 with HEI, no problems. How does it not fit, exactly?
And have you actually been on a Bigfoot expedition?!
Macadoo is offline
Old March 10th, 2015, 07:09 AM
Dbechtel71's Avatar
I'd have to check the numbers on the manifold. The distributor won't slide all the way Down as it hits the manifold. And yes I have been on an expedition in the Adirondacks. lol! was a lot of fun
Old March 10th, 2015, 07:11 AM
Dbechtel71's Avatar
The cap hits the manifold so it won't let the distributor slide all the way down
Old March 10th, 2015, 07:51 AM
The cap?
Old March 10th, 2015, 09:37 AM
Octania's Avatar
grind some away
you don't really need all that anyhow.
Octania is offline
Old March 10th, 2015, 01:36 PM
I have used the 3711 Performer 350 and 7111 Performer RPM with the same HEI and no clearance issues. Since we're in the Big Block forum I'm not sure our experiences with Small Blocks translates to the OP's issue.
Fun71 is online now
Old March 10th, 2015, 02:25 PM
same but different
don71's Avatar
Until we get further information, the only manifold that I can think of is the older Edelbrock O4b that might cause that problem.
Grinding a little in the right spot should take care of it. You only need a little room.
don71 is offline
Old March 10th, 2015, 03:09 PM
Macadoo's Avatar
I didn't catch that. Thanks Kenneth.
Macadoo is offline
Old March 10th, 2015, 03:11 PM
Macadoo's Avatar
Although the one I bought off of eBay says that it fits 350 and 455. So do most of the others.
Macadoo is offline
Old March 10th, 2015, 04:26 PM
The HEI or the intake manifold?
Fun71 is online now
Old March 10th, 2015, 06:24 PM
Macadoo's Avatar
Lol!
Macadoo is offline
Old March 11th, 2015, 09:58 AM
Oldsragger's Avatar
HEI with edlbrock performer 455 intake, not good clearens if adjusting timing much with out find the right posission from firewall and intake.
Oldsragger is offline
Old March 19th, 2015, 04:30 AM
Dbechtel71's Avatar
Well I've decided to put in a points distributor with pertronix ignition. Figured would be the easiest solution
Old March 19th, 2015, 03:59 PM
jcmoretti's Avatar
I have and Edelbrock Olds 455 Performer with HEI that fits just fine.
jcmoretti is offline
Old March 19th, 2015, 05:10 PM
Dbechtel71's Avatar
I think I have an older edelbrock intake.
Old March 19th, 2015, 05:25 PM
Does it have a number on it? An HEI should work with a standard performer manifold.
Old March 19th, 2015, 05:32 PM
Dbechtel71's Avatar
I'll have to look at the number can't remember it won't slide all the way down the distributor shaft as it hits the manifold
Old March 19th, 2015, 05:33 PM
oldsmobiledave's Avatar
Fyi
The factory W-455 intake works fine with HEI. I have been running that set up on my 1972 W-30 for 20 years
oldsmobiledave is offline
Old March 19th, 2015, 05:39 PM
Can you post some pictures of the distributor and where it hits?
Old March 19th, 2015, 05:45 PM
Dbechtel71's Avatar
Wow yours has a ton of room mine rubs on the intake when adjustimg
Old March 19th, 2015, 05:46 PM
Dbechtel71's Avatar
I'll try I won't be able to till this weekend plus the motor is in the car now so it may not be that easy.
Old March 19th, 2015, 05:49 PM
Dbechtel71's Avatar
Can't remember how to post a picture to this thread.
Old March 19th, 2015, 07:45 PM
Go to advanced and click on the paperclip.
Old March 20th, 2015, 03:40 AM
Dbechtel71's Avatar
The only number I can see is 04B on the intake
Old March 20th, 2015, 06:13 AM
An HEI will not work with an 04B manifold. You will have to use a points distributor and/ or convert it to an electronic.
Old March 20th, 2015, 01:16 PM
Dbechtel71's Avatar
Yea I'm assuming because it's an older manifold.
Old March 20th, 2015, 01:17 PM
Dbechtel71's Avatar
I just picked up a pertronix ignition and coil as my brother had a new points distributor.
Old March 20th, 2015, 02:33 PM
same but different
don71's Avatar
Here is a video of an Olds 455 with the O4B using an HEI. It might not work in every application given certain tolerances. A little grinding might do it though.
don71 is offline
Old March 20th, 2015, 02:51 PM
  #31
Oldsragger's Avatar
wow thats awsome sound, speacially on my speakers and subwoofers , the walls are shaking, lol
Old March 20th, 2015, 06:19 PM
  #32
Dbechtel71's Avatar
Oldsmobile 455 Engine For Sale - Street Strip - YouTube
Thanks I would love to be able to use my brand new hei ignition but I'll probably just go with the standard ignition.
Old March 20th, 2015, 07:47 PM
  #33
How much did he have to grind off? I was always under the impression that it just won't fit.
tocicar8825
September 21st, 2021 07:10 AM
joepenoso
June 4th, 2014 01:56 PM
TIM FISKUS
May 12th, 2013 05:17 AM
svnt442
July 17th, 2011 04:43 PM
oldscruiser
February 15th, 2011 12:44 AM
Quick Reply: aluminum intake with hei
