Advice on Heads
Advice on Heads
I am going to rebuild the 1973 455 that I bought for my 70 Cutlass. Not wanting to get wild radical. Just wanting 350-400 hp and the magic 500 ftlbs of torque. My motor has the J heads. Can I get there from here or do I spend a little and get K,G,? Im on a budget so any help would be appreciated.
I have a set of large valve c heads complete 3 angle valve job,egr bumps ground down, and they have Harland sharp s50026a roller rockers. They have less than 1000 miles on them.
Over reved my g block 400 and spun a connecting rod bearing. Also have performer intake and 750 electric choke edelbrock carb from the same engine.i would have to pull it all off the engine that's still in car. Your in Texas and I'm in Connecticut,I never shipped anything this big or heavy. I'm going to build a 455 and most likely will be going with edelbrock heads.
Consider Fastenal for shipping heavy stuff like iron heads
Fastenal, the bolt and nut people, have started accepting fairly large and heavy items for shipment between their stores. Rates are way better than truck freight or UPS/FedEx. If there is a Fastenal store anywhere near you and the place you may be shipping you might give them a call. I understand it is a space available and may take a few days more than UPS. Wouldn't hurt to give them a call and check. You can also locate their stores on the Internet. I've also had good luck with Greyhound Bus Freight but again it is not door to door but is a lot less than the big guys.
I have no connection with either fastenal or greyhound so nothing in it for me.
Jerry
