Adjusting Idle Mixture Screws
Old Jul 3, 2016 | 03:21 PM
ben442's Avatar
Is there a specific number of turns out for these screws on this carb Number7041253 RE?
I started the car and hooked up a vacuum gage but got no reading from the port that I connected to. There are 2 lines on the front of the carb, both on the front right. I connected to the line that was not blocked off.
Carb is on a 455 with manual transmission
Old Jul 3, 2016 | 04:18 PM
ben442's Avatar
Here is an image of the two lines, The top gave me no reading on the gage.
Old Jul 3, 2016 | 04:20 PM
You connected the gauge to the ported vacuum port. It needs to be on the manifold vacuum port. The bottom port with the screw in the hose should work. If its an automatic, look for the line that goes to the trans, you can use that one. Adjust the left and right screws the same amount of turns to reach the highest vacuum on the gauge and then turn them in a 1/4.
Old Jul 3, 2016 | 06:45 PM
RetroRanger's Avatar
72 Olds CS
I think the start point is 6 turns out
Old Jul 3, 2016 | 08:14 PM
Technically, there is no starting point for idle mixture screws in 1971, because they were set at the factory and capped.
However, in 1970 the recommendation is, in fact, for 6 turns, so that looks like the best place to start.
Old Jul 4, 2016 | 06:55 AM
I don't remember them being blocked off in 71, I remember that starting in the mid to late 70's.
Old Jul 4, 2016 | 07:00 AM
I know, I didn't either, but that's what the CSM says, right where it usually tells you how many turns to start at.
Old Jul 4, 2016 | 07:52 AM
I believe the early 70s carbs had plastic limiter caps on the screws that only allowed a quarter turn or so adjustment. It wasn't until later that the lead plugs were used.
The screws with the tapered heads are designed to allow the plastic caps to snap over them.
Old Jul 5, 2016 | 05:32 AM
I thought the recommendation was 2.5 turns?
Old Jul 5, 2016 | 05:38 AM
That's what I thought as well. 2.5-3 turns out from fully seated as the starting point on a rebuild, then obviously adjusted as required with a vacuum gauge.
Old Jul 5, 2016 | 05:41 AM
Personally the starting point in turns is irrelevant, its the ending point that matters. The 2 idle a/f mixture screws should be equal in the same amount of turns when done.
Old Jul 5, 2016 | 05:45 AM
True, but it's easier to get to the end point if the engine starts more quickly.
Old Jul 5, 2016 | 05:52 AM
The biggest problem I've seen in peoples posts are the idle rpm is too high when they start and the a/f mixture screws do nothing when adjusted. The engine is pretty forgiving in starting whether very rich or lean. Anything from 2 to many turns out will get it to start. Its more important that the engine is warmed up, with the choke off and running with the idle rpm as close to what the book calls for when you adjust it. The carb needs to be adjusted last after dwell/timing is set.
Old Jul 5, 2016 | 06:03 AM
You mean as instructed in the CSM?
Old Jul 5, 2016 | 06:19 AM
Which is exactly what I thought when I first read this question, and what I've always done, but I try hard no to give people inaccurate information, so I went to a couple of CSMs to double-check, and darned if it didn't say 6 turns.
Who knew?
Old Jul 5, 2016 | 06:37 AM
Who knew?
Now you're going to make me check all my CSMs...
Old Jul 5, 2016 | 06:44 AM
I only checked 1971 (the year of his carburetor), which said they were plugged, and then back one year to 1970, which has a table within the QuadraJet adjustment section, which gives the number of turns for each engine code.
I wonder about the other years, too.
Old Jul 5, 2016 | 09:32 AM
Octania's Avatar
So, if adjusting the idle mixture screws makes no difference at all...?
Old Jul 5, 2016 | 09:37 AM
Vacuum leak or the throttle blades are open too far.
Old Jul 20, 2016 | 01:02 PM
ben442's Avatar
another issue with this carb...
after sitting for a few days it's turns over a fair bit before firing up. It's not shooting any gas into the carb when I manually pump the throttle at the carb.
The bowls are empty I guess, Why? Do I need a rebuild?
Ben
gehrig44
Sep 6, 2015 10:44 AM
leroycjr
Aug 27, 2015 03:46 PM
Seff
Sep 20, 2012 04:46 PM
al714
Nov 13, 2011 11:24 AM
Chumley
Aug 9, 2008 08:02 AM
