Adding dual exhaust on 1970 98 LS
Old September 23rd, 2022, 06:19 PM
  #41
There are no "spring bolts". I used stainless studs and nuts on mine. Original was bolts (sans springs). Note that unlike most Olds exhaust manifolds, these do use "donunt" seals between the manifold and the pipe. The correct ones are no longer available. I found some that were close. No, they are not the same as on an A-body. The flange and pipe diameter is different.
joe_padavano is offline
Old September 23rd, 2022, 07:46 PM
  #42
2blu442's Avatar
Originally Posted by smparr
Okay, cool. What about the spring bolts? Are they the same as a A body 455 exhaust?
I believe the bolts are the same diameter. So the bolts/springs should interchange.
2blu442 is offline
Old September 23rd, 2022, 07:48 PM
  #43
2blu442's Avatar
I didn't see Joe's post and had forgotten these used the doughnut.
2blu442 is offline
Old September 23rd, 2022, 11:27 PM
  #44
smparr's Avatar
I got some donuts off RockAuto that are supposed to be for this car, Felpro 2 1/8" ID. The shop manual made it look like the flange bolts had springs around them. Thanks for the clarification.
smparr is online now
Old September 25th, 2022, 07:33 AM
  #45
sysmg's Avatar
I used Stainless Steel studs and brass nuts.
-Stew
sysmg is offline
Old September 28th, 2022, 12:14 AM
  #46
smparr's Avatar
The 1970 B/C Body uses a 2 1/4" exhaust right? The pipe going back on the car is 2 1/4" and it also says 2 1/4" on the clamps, but the 2 1/4" flanges with the round bolt holes I got from Thornton don't line up with the bolt holes on the S Manifold. I'm going to exchange the fixed round bolt hole 2 1/4" flanges for the slotted bolt hole 2 1/4" flanges and hopefully that works.
Old September 28th, 2022, 04:08 AM
  #47
The big car manifolds use different flanges than the A-body ones sold by Thorntons and others. I was able to reuse my old ones.
Old September 28th, 2022, 05:24 AM
  #48
Oldsmaniac's Avatar
Olds did use "spring bolts" I know on the 66 full size cars but you are better off with a stud kit and nuts.
Oldsmaniac is offline
Old September 28th, 2022, 10:44 PM
  #49
smparr's Avatar
What exactly do the springs do?
Old September 28th, 2022, 10:45 PM
  #50
smparr's Avatar
I can try to reuse the old flanges but the studs are pretty rusted.
Old September 29th, 2022, 02:18 PM
  #51
sysmg's Avatar
I think the springs in theory allowed for some movement of the exhaust pipe relative to the exhaust manifold, while maintaining pressure on the doughnut. However with all the exhaust heat, I would bet they lost tension over a number of years and were ineffective.
sysmg is offline
1yesfan
December 15th, 2015 09:35 AM
hmartin
Ninety-Eight
January 18th, 2012 06:22 AM
JJRitchey
January 11th, 2012 06:20 PM
PushRod
February 16th, 2011 09:41 AM
Delance318
June 15th, 2009 10:19 AM
Quick Reply: Adding dual exhaust on 1970 98 LS
