73-75 455 short block
Would this be a good block to start, as a mild performance motor? Any drawbacks to a mid 70's 455 block? Here are numbers on the block 396021 FA. No heads, just the block with crank, rods, and pistons.
Thanks Tom
Thanks Tom
Ok got the short block checked out, it's stock. Has been magna fluxed and checks out. The only parts that came with the block, are the crank and 7 rods (yes just 7 will need 1 if I stay with stock rods) everything else has to be bought. When I am done I would like it to produce between 400-425 hp. I do realize that there are other factors, I am thinking of a TKO 5 speed and a 3:09 posi rear. Not set in stone. I do plan to use edelbrock heads an intake. Looking for some input on other items. Compression and cam, being the questions.
Question: What are you basing decking the block .025" off of? I'm asking because he said 400-425 hp and it seems that if you arbitrarily deck the block .025" you would bring compression up drastically. I had my deck taken down .006" and I'm at 10.63:1 compression w/ Keith Black flat tops and a .054" head gasket. I would only take off what is needed to clean up the block and let the piston/ gasket combo make the compression number you need.
Normally the decks are bit high, taking .025 off just brings it even in most cases.
I had +.003 deck clearance on this last one with KB IC886's and Edelbrock heads, came to 10.3:1 with a .043 gasket.
Same same, IC886/KTD, but .060" oversize. This is the second time this motor has been built, the first time by a crummy spit 'em out shop when I was in high school. I have no idea what they took off the deck, if anything.
The latest build was done by Nickens Brothers Racing Engines here in the Houston area. I do know that Nickens took off .006" but it was done in Dec. 2009 and I know they told me but I don't remember the deck height by now. I assumed that the CR was so high because of the flat top piston but it could be that the previous builder took off .020" who knows. I was in high school, on a budget and looking for BBO power. I got it cheap, and it lasted for 3 years before it spun a rod bearing.
I should correct my earlier statement, I remember having Nickens calculate the CR w/ a .040" head gasket, the .054" gasket is what I ended up with. When I built the short block I wasn't sure if I was gonna end up w/ the Edelbrock heads so I used a Felpro cast iron head gasket thickness to be on the safe side.
1971viking
December 10th, 2012 10:59 AM
j_link
August 18th, 2011 03:13 PM
