72 Cutlass / 425 super rocket
Old July 22nd, 2007, 11:25 PM
1972madison's Avatar
i might buy this motor for my 1972 cutlass, would it fit into my car ?
Here is what the guy said:
Description: I have a 425super rocket ultra high conpression It has 1500 mile since it was rebuilt This moter has 390 horse power and it is stock It has a 400 turbo tranny cross member and drive shaft and is ready to install this moter is VERY FAST so be prepard I'M asking $500 Canadian
WOULD IT FIT ?
1972madison is offline
Old July 23rd, 2007, 05:40 AM
2blu442's Avatar
Yes it would. Externally it's the same as a 455 so if you use the correct motor mounts and exhaust manifolds it should fit just fine. John
2blu442 is offline
Old July 23rd, 2007, 07:32 AM
First, simply use the motor and frame mounts already in the car. If you buy 455 motor mounts, you'll need to change the frame mounts to match. If you keep the 350 mounts, the motor will bolt in with the 350 frame mounts. Olds motor and frame mounts are dimensionally equivalent if you use them in matched sets, but don't mix and match - they won't fit.
If the trans is out of the same full size car as the 425, it will almost certainly be a long tailshaft TH400. It will fit in an A-body but will require a custom shorter driveshaft. Your current crossmember works fine.
joe_padavano is online now
Old July 23rd, 2007, 10:55 AM
does this sounds like a good engine ?, is this kind of engine built good ?
Old July 23rd, 2007, 10:11 PM
2blu442's Avatar
Personal preference, the 425 was never put in the Cutlass/442 line but only used in full sized cars. They do have a forged steel crank which is stronger than cast iron, and a shorter stroke than the 455. Bolt on parts will interchange, like heads, intake and exhaust manifolds, but internal parts such as lifters and pistons are harder to find for the 425. The 455 was made for more years and is a newer engine. I like them both, and if you find a good deal on one or the other I would take it. That's my 2 cents worth.
2blu442 is offline
Old July 23rd, 2007, 10:13 PM
But is the 425 super rocket build strong, and would it have some power ?
Old July 24th, 2007, 12:16 AM
shaks 442 clone's Avatar
390 horsepower is a ridiculous amount of hp stock so yes it will be a strong motor an also a powerful one
shaks 442 clone is offline
4-ever-olds
September 17th, 2012 06:29 AM
JWW
June 16th, 2007 09:53 PM
<rocket powered>
February 8th, 2005 05:05 AM
<425superrocket>
October 14th, 2004 08:18 PM
Paula
August 10th, 2003 10:22 PM
Quick Reply: 72 Cutlass / 425 super rocket
