72 Cutlass / 425 super rocket
Old Jul 22, 2007 | 11:25 PM
1972madison's Avatar
i might buy this motor for my 1972 cutlass, would it fit into my car ?
Here is what the guy said:
Description: I have a 425super rocket ultra high conpression It has 1500 mile since it was rebuilt This moter has 390 horse power and it is stock It has a 400 turbo tranny cross member and drive shaft and is ready to install this moter is VERY FAST so be prepard I'M asking $500 Canadian
WOULD IT FIT ?
Old Jul 23, 2007 | 05:40 AM
2blu442's Avatar
Yes it would. Externally it's the same as a 455 so if you use the correct motor mounts and exhaust manifolds it should fit just fine. John
Old Jul 23, 2007 | 07:32 AM
First, simply use the motor and frame mounts already in the car. If you buy 455 motor mounts, you'll need to change the frame mounts to match. If you keep the 350 mounts, the motor will bolt in with the 350 frame mounts. Olds motor and frame mounts are dimensionally equivalent if you use them in matched sets, but don't mix and match - they won't fit.
If the trans is out of the same full size car as the 425, it will almost certainly be a long tailshaft TH400. It will fit in an A-body but will require a custom shorter driveshaft. Your current crossmember works fine.
Old Jul 23, 2007 | 10:55 AM
does this sounds like a good engine ?, is this kind of engine built good ?
Old Jul 23, 2007 | 10:11 PM
2blu442's Avatar
Personal preference, the 425 was never put in the Cutlass/442 line but only used in full sized cars. They do have a forged steel crank which is stronger than cast iron, and a shorter stroke than the 455. Bolt on parts will interchange, like heads, intake and exhaust manifolds, but internal parts such as lifters and pistons are harder to find for the 425. The 455 was made for more years and is a newer engine. I like them both, and if you find a good deal on one or the other I would take it. That's my 2 cents worth.
Old Jul 23, 2007 | 10:13 PM
But is the 425 super rocket build strong, and would it have some power ?
Old Jul 24, 2007 | 12:16 AM
shaks 442 clone's Avatar
390 horsepower is a ridiculous amount of hp stock so yes it will be a strong motor an also a powerful one
4-ever-olds
Sep 17, 2012 06:29 AM
JWW
Jun 16, 2007 09:53 PM
<rocket powered>
Feb 8, 2005 05:05 AM
<425superrocket>
Oct 14, 2004 08:18 PM
Paula
Aug 10, 2003 10:22 PM
