72 CS AC Compressor Clutch Assy Squeaking
Hello
Had our 72 Cutlass Supreme (Rocket 350) out today and notice a squeaking sound from under the hood. Upon opening it sounds like it is coming from the AC unit. The AC unit doesn't work and is not engaged. I'm guessing the AC clutch assembly bearing is going bad at a rapid rate.
AC Model is Frigidaire 5910781. Anyone know what the clutch assy part number might be and where I can find a replacement. Also any tips on disassembly would be appreciated.
Dean
Dean
rockauto has this for ~$53...if you search this site you find find a discount code for 5% off as well
OLDSMOBILE 1972 CUTLASS SUPREME 5.7L 350cid V8 Heat & Air Conditioning A/C Compressor Clutch
ACDELCO 1541 {#05914719, 5914719} Professional
Info
Engine VIN H; Engine VIN K; A6 compressor, CLU DRIVER
Info
Thank You
I see they have an AC Compressor Bearing for sale too. Is that a part of the clutch assy? Are they separate items that should both be replaced. Any way to narrow down one or the other. Will it free spin once I take the belt off?
dn
dn
Hello
Dean
Dean
After you remove the belt the pulley will free spin assuming that the bearing has not seized. It should feel smooth without any looseness or binding. The front of the pulley is the drive surface of the clutch. The driven portion is the part in front of the pulley. After dis-assembly you will be able to tell what needs replacement.
Thanks all - Belt is off and the noise is gone. I didnt have much time this morning to play with it other than to pull the belt, but will investigate further tomorrow. Being lazy and not walking out to the car, does this have a compressed fit clutch or is there a center nut that will allow the clutch to be free off the pulley. Will a local auto store likley have the compression removal tool to loan or rent if needed.
I can never recall the AC working in the car. Its likely that it was INOP last time my Grandfather drove it in 1986. Is there a way to test it or do I need to charge it up and see if it all leaks out in a week or so.
THX
dean
THX
dean
Have someone put some gauges on it, and see if there is Freon in the system. If it is charged, then you will need to have it evacuated, to replace the bearing in the clutch assembly. Chances are that it has no charge, and it might need a flush and some parts replacement. The bearing is a sealed unit, that you can open up, clean, and re grease. If you have the proper tools, it isn't a difficult job, but without the tools, it is an impossible job. If the car is a driver, and you don't care about matching numbers, then just purchase a reman unit, and install it. You could probably sell the original compressor to someone that is looking to put a car back to original for more than the core charge on the replacement compressor.
![Post](https://classicoldsmobile.com/forums/images/icons/icon1.gif)
THX
dean
THX
dean
![EEK!](https://classicoldsmobile.com/forums/images/smilies/eek.gif)
turnerp
Brakes/Hydraulic Systems
April 20th, 2006 01:20 PM
