Squeaking rear suspension
I just replace all of the rear suspension components in my 69 cutlass and now im getting a squeaking sound when i push down on the back bumper. It didnt happen right away, but after driving it for a few days, its starting to squeak. It has new shocks, springs, boxed lower control arms, and bushings. Everything is stock replacement parts and installed and torqued to spec. It looks and rides great but the squeaking in kind of getting annoying. How do I go about fixing this?
Yes i did replace the upper spring insolators. One thing i forgot to mention, i used wheel bearing grease on the bushings to help install the control arms on the car. I have been doing a little research and have heard that this may be the cause of my squeaking. Will i have to replace my bushings again or is there a way to fix this?
I'm not sure how grease would cause squeaking - seems it would have the opposite effect.
Did you use rubber bushings? If so, did you have the weight of the car on the suspension when you torqued the bolts to spec? As in, was the car sitting on the ground with the suspension loaded? Or was the axle hanging down with the body up on stands? The rubber bushings need to be torqued when they are in their "neutral" position, otherwise they may be in a bind.
I used rubber bushings and torqued all the bolts with the weight on the suspension. I have heard that petroleum based grease may cause rubber to swell and therfore cause a squeaking noisy. I really hope i dont have to take everything apart again becase it was a real PIA.
They didn't squeak from the factory, so why should you need to grind anything? Figure out what is assembled incorrectly and fix THAT.
A-body cars use the same arms on both sides - there is no RH/LH distinction. If you can get the uppers and lowers reversed, you are the Incredible Hulk. There's about a 3:1 difference in length, not to mention that the uppers only have bushings in the front end, as they fit over the bushings pressed into the axle housing at the back end of the arms. The lowers have bushings in both ends of the arms.
turnerp
Brakes/Hydraulic Systems
Apr 20, 2006 01:20 PM
