`71 Delta...350 To 455 Swap ???
Old Oct 17, 2009 | 08:35 PM
davesdelta's Avatar
Is this a simple bolt in swap ? What differences are involved...vaccuum lines, wiring, brackets...etc ???
Old Oct 17, 2009 | 08:51 PM
70 cutlass s's Avatar
Its about as simple as can be use the brackets everything. Strait bolt in swap
Old Oct 17, 2009 | 08:57 PM
davesdelta's Avatar
Seems there is a much larger pool of after market options for the 455s over the 350s. Thanks 70....Anyone else with details on such a swap ?
Old Oct 17, 2009 | 09:15 PM
citcapp's Avatar
Like 70 cutlass says straight up swap. the only difference between the 455 and the 350 is the deck height of the block. Fights right in. Use motor mounts from the 350 and your set. The turbo 350 in its stock form is not up to the torque of the 455 and your need to either have it built up or change to a turbo 400. The are several past threads in this site that outline the swap Use the search function to find them.
Old Oct 18, 2009 | 05:02 AM
2blu442's Avatar
X3 with the other guys, easy project to get more cubes/torque. If you change from a TH350 to a TH400 you'll need to shorten the driveline. A while back I dismantled a 1971 Delta 455/HT400 car and believe I still have the driveline if you need it. John
Old Oct 18, 2009 | 09:29 AM
[quote=citcapp;116601Use motor mounts from the 350 and your set. [/quote]
Actually, the full size cars used the same motor and frame mounts for all BBO and SBO. The different mounts problem only applies to the 69-72 A-body cars.
Sanghi
Jun 2, 2015 03:48 PM
falconsfan
May 14, 2015 05:47 AM
oldrelics
Non-Olds Engines
Jun 12, 2014 07:09 PM
whizkid88
Mar 12, 2010 09:05 PM
Charger1973
Dec 3, 2006 08:43 PM
