1965 F85, 330 to 455 Engine SWAP
Old Oct 18, 2009 | 03:45 PM
Schober Motorsports's Avatar
Well this weekend I am going to have a 4 day weekend due to some teacher institute days and hopefully this 455 is gonna get dropped in. I bought this motor off some farmer in Indiana who found the motor sitting in a field for a whole 400 bucks, transmission included. When we went to go pick it up I saw those C heads and took that thing right up. Brought it home and as I dug deeper into it I did some measurements and saw that it was already 40 over, jack pot! Now its about 5 months later and about 60 degrees colder and this motor is getting closer to completion. Now what I am looking to learn is that, is there any tricks or tips I should do when putting this thing together? I already have about 2 and a half thousandths clearance on the mains and about same on the rods so my clearances are good, as J-Chicago told me about. Now what about some tricks to make sure this thing ain't gonna leak or anything like that.
Also can anyone tell me what kinda compression I'm gonna be running here? I remember hearing something about you can tell by the dish of the pistons like 30 or 40cc's or something like that someone please correct me on that one.
Thanks in advance!
-Craig
Oh and, I had to go with orange...
Old Oct 18, 2009 | 04:29 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I recommend .0025-.0029 on the rods, and .0030-.0035 on the mains.
You can CC your piston dish with an old CD case. Cut a circle out of the front cd cover a little bit smaller than the bore. Then drill some holes in the center of it to let water in and let air out. Smear some wheel bearing grease around the outside of the dish and stick the plastic cover on. Use an eye dropper or the like to fill the dish with water. Milliliters and CC's are the same thing. From here, those look like 30 cc pistons.
Old Oct 18, 2009 | 04:32 PM
.0020-.0025 on the mains isn't enough clearance in my opinion, especially on 2 and 4
You might want to get your crank machined down a little.
Old Oct 18, 2009 | 04:57 PM
What kinda compression is it with the 30cc pistons and C heads?
Old Oct 18, 2009 | 05:32 PM
With Fel-pro gaskets and .040 piston to deck.... roughly 8.3 to 1.
Old Oct 18, 2009 | 05:38 PM
Cylinder Head Volume (cc) 80?
Piston dish 30?
gasket thickness .043?
Gasket Bore (in.) 4.2?
Cylinder Bore Diameter (in.) 4.166?
Piston to deck .040?
Stroke 4.25
Lot of unknowns here.
Old Oct 18, 2009 | 10:06 PM
64Rocket's Avatar
To bad you used sh__"orange"
Gene
Old Oct 19, 2009 | 10:32 AM
1964f-85's Avatar
what is the matter with orange?
Jonmueller1
Sep 10, 2013 06:48 AM
65CutlassClint
Aug 4, 2013 12:12 AM
belairbob
Aug 15, 2012 07:11 PM
bubbasz1
Jun 18, 2011 10:45 AM
OldGuy
Nov 16, 2009 02:40 PM
