350 swap in place of a 455?
Old Dec 3, 2006 | 12:30 PM
Charger1973's Avatar
Is this possible? Just wondered if everything would bolt up and work ok.
Old Dec 3, 2006 | 06:47 PM
coppertopgmc's Avatar
If your talking about a 350 Oldsmobile then yes. 350 chevy NO. 350 Olds and 455 both use the same motor mounts and bell housing pattern. the only thing that may be different mat be the brackets.
Old Dec 3, 2006 | 08:43 PM
2blu442's Avatar
What year and model of car do you want to make this swap in? I agree with coppertopgmc, I've made the swap a couple times and its not hard. The key I've found is that if you are keeping the 350 metal perches that are bolted to the crossmember of the frame, then you need to use 350 rubber motor mounts. If you want to change over to the 455 metal perches, then use the 455 rubber mounts. I've done this swap in 1968-72 Cutlass's and I don't think I had to change the brackets. On one I did need to take the pullys off the 350 and put them on the 455 to get the belts to line up with the power steering pump. If you get into it and find problems, I'm sure there's lots of guys here who can share their experience. John
falconsfan
May 14, 2015 05:47 AM
oldrelics
Non-Olds Engines
Jun 12, 2014 07:09 PM
BerBer5985
Jul 9, 2009 03:58 PM
mcutlass1969
Jun 11, 2009 06:27 AM
shaks 442 clone
Jul 29, 2007 09:27 PM
