71 Cutlass Radiator replacement help
Old Apr 28, 2026 | 07:17 AM
JVCCutlass's Avatar
Hi All - the radiator in my 71 ragtop needs replacing and I would like to get some recommendations as to which one will be a drop-in replacement. It's a stock 350 cid engine.
Many listing on ebay and other sites are a bit confusing and I am concerned about getting the wrong one, especially with the wrong size for the hose diameters. I've not taken the old one out yet but I know it is the original from when I first got the car in 1974.
Any hep and suggestions are appreciated !
Thanks in advance
Joe Hackettstown, NJ
Old Apr 28, 2026 | 11:55 AM
Most of the aftermarket stuff is for the '71-newer engines with the smaller diameter lower hose, so you should be OK there. It's finding the parts for the '70-older that have the larger diameter lower hose is the problem.
Old Apr 28, 2026 | 05:05 PM
If you can find a real radiator shop nearby, have the original recored.
Tancuda
Sep 2, 2024 07:26 AM
Bobby455
May 9, 2020 07:17 AM
mat1227
Dec 13, 2016 06:10 PM
truckman5000
Jun 9, 2016 01:44 PM
Rocketbrian
Apr 12, 2012 10:00 AM
