66 toro camshaft
Old Dec 24, 2023 | 06:43 AM
Jetmek's Avatar
66 toro camshaft
Im beginning a rebuild on my 425. Can someone recommend a source to have my cam/ lifters reground? OR a new set? I usually go to schneider cams for grinding but i want to be sure to get the right profile. Stock p/n is 390961. Also any thoughts on new lifters? Shops in my area wont even use flat tappet cams any more due to lifter failures. Thanks!
Old Dec 24, 2023 | 08:00 AM
67OAI's Avatar
Old(s)GuysRule
You may want to contact these folks, CAMCRAFT, they have been mentioned in here in the past. If this is in fact a Toronado 425 engine block it shall have the 0.921" diameter lifters and Mark Remmel, known as cutlassefi in these forums, would most probably have the correct non-Chinese made lifters.
442 Phillipsville Loop
Canton, NC, 28716
Phone (828) 681-5183
Toll Free (800) 426-2261
Fax (828) 681-5185
Email: hunter@camcraftcams.com
Old Dec 24, 2023 | 08:24 AM
Sugar Bear's Avatar
Might be best to source the lifters and camshaft from the same supplier if that's possible. It could take one aspect of "finger pointing" out of the equation if there is a failure of either part.
Old Dec 24, 2023 | 08:25 AM
Jetmek's Avatar
Canton, NC, 28716
Fax (828) 681-5185
thank you!
Old Dec 24, 2023 | 01:12 PM
v8al's Avatar
Registered Olds Owner
See this post for resurfacing lifters: Help ID .921 lifters
cfair
Jun 15, 2022 10:45 AM
oldstoro66
Aug 3, 2017 10:36 PM
lemoldsnut
Tech Editor's Desk
Jun 29, 2015 10:26 PM
ijasond
May 13, 2008 08:27 AM
66 Olznut
Mar 29, 2007 05:29 PM
