66-67 400 Block ID Help Needed
Old Dec 6, 2010 | 07:04 AM
bobb's Avatar
Hi Guys,
If I find a 66-67 400 "E" block (casting #390925) without heads....how do I know if it was made in 66 or 67? I'm asking for a friend, so please excuse my ignorance here.
thanks,
bob
Old Dec 6, 2010 | 08:01 AM
aliensatemybuick's Avatar
"me somebody" site member
As far as I know, there is no way to distinguish between a '66 and '67 "E" block, especially if the heads and other year-specific parts are removed. The julian date markings would narrow down to time of year, but the year itself is not specified anywhere.
I'm sure if I am wrong about this, others will let you know! Good news assuming I am right is that either year block can be used to make a '66 or '67 442 "correct".
Old Dec 6, 2010 | 08:09 AM
As an addendum, assuming I am right above, the same is likely also true of a Toronado "D" block, since the lifter bank angles on both "E" and Toro "D" blocks was 39 degrees for both years.
And if I am wrong above, then I guess my embarrassment will be doubled now.
TicTocTach
Jun 16, 2015 04:03 PM
stonecad
Feb 11, 2014 02:02 PM
2Olds4U
Jun 25, 2013 03:28 PM
chrisneu68olds
Dec 30, 2011 10:17 AM
