66 442 Throttle return spring ?????
Old April 2nd, 2010 | 11:31 AM
4-Speed's Avatar
Anyone have an on the engine picture of the correct throttle return spring and bracket for a 66 442 4-speed car? Anyone have an extra bracket and spring for sale?
Dave
71rt4spd@roadrunner.com
Old April 2nd, 2010 | 11:35 AM
Run to Rund's Avatar
Qjet or Tri Carbs? post an email address and I can send a photo to you of the latter.
Old April 2nd, 2010 | 12:00 PM
4-Speed's Avatar
Sorry, I should have mentioned 4-BBL.
thanks-
Old April 2nd, 2010 | 01:44 PM
The difference is the L shaped bracket. The top leg is longer for Tri Carbs.
Old April 2nd, 2010 | 01:46 PM
4-Speed's Avatar
Is that where the spring is located? On the bell crank? If so so my spring is missing.
Old April 2nd, 2010 | 01:54 PM
aliensatemybuick's Avatar
"me somebody" site member
The return srping is part of the bellcrank, goes from a "tab" the "L" bracket" that the throttle rod connects to, to another "tab" on the part of the bellcrank assembly that bolts to the firewall. As far as I know, there is no diff between 4 bbl and trr-carb cars with respect to the spring.
You could use a secondary spring from the carb linkage to the "loop" on the intake manifold (or somewhere else) for extra caution, but it would not be "factory".
Old April 2nd, 2010 | 02:16 PM
67Olds442X2's Avatar
Navy P-3 FE (Ret.)
Hi Dave,
The spring is in this picture, I think the one I sent to your e-mail was unreadable. Figured I'd post it here. This is from my 67 manual, 66 probably similar. I used to have a backup spring attached to the engine lift hook.
Dan
Old April 2nd, 2010 | 02:27 PM
Navy P-3 FE (Ret.)
Dave,
I just went out to my Blue car and the spring is missing on mine also
I was going to pull it and try to find a duplicate. Hey but looking at the picture, the auto is the same. My Ivory car has the spring, I'll hook you up if need be.
Dan
DRXOLDS
March 2nd, 2015 07:29 AM
mv64cutlass
July 20th, 2011 06:05 AM
defiant1
May 12th, 2011 10:32 AM
Flye
August 30th, 2009 05:18 AM
68conv455
May 20th, 2008 02:03 PM
Quick Reply: 66 442 Throttle return spring ?????
