65 hood clearance
Old Apr 11, 2018 | 11:19 AM
crmayer's Avatar
65 hood clearance
I'm having a similar issue. I've got a 65 Cutlass 442 with a 68 455 engine.
The prior owner install a Holley Street Dominator intake with a Demon carb. This leaves me with very little room for an air cleaner. I am going to replace this induction system with a Edelbrock 2151 intake and Fitech fuel injection system. Has anyone used the Chevy L88 drop base air cleaner with success? I don't want to buy it and then dam it dose not fit.
Any help will be greatly appreciated.
Old Apr 11, 2018 | 01:24 PM
Welcome to the site. I moved your post to its own thread as your problem is really not similar to clearing an OAI hood.
This repro Chevy drop base is the lowest I was able to find to clear a 67 hood. Its a quality piece:
http://www.ss396.com/chevelle/ATE-3907.html
Old Apr 16, 2018 | 07:57 AM
Tiha's Avatar
what i can say is: in 65 / 455 with the correct height motor mounts the Performer or the torker Intake with the EDE Carb will fit with a drop base carb under the hood ...so compare the intake and carb height
Old Apr 16, 2018 | 07:58 AM
Tiha's Avatar
Moroso sells are drop base cleaner too
Old Apr 16, 2018 | 08:18 AM
Just a note, the air cleaner I suggested will not work with an Edelbrock w/choke.
Old Apr 16, 2018 | 11:40 AM
crmayer's Avatar
The Fitech fuel injection unit is constructed like an Edelbrock carb without a choke. I will let you all know what the final results are.
Old Apr 19, 2018 | 03:07 AM
Tiha's Avatar
great
Old Apr 19, 2018 | 09:09 AM
Rocketguy's Avatar
What about an early Toronado air cleaner?
oregontopcat
Jan 31, 2014 06:31 PM
455cutlass1969
Apr 9, 2012 11:13 AM
toms vista
Sep 24, 2010 08:33 PM
808olds
Sep 16, 2010 11:38 PM
Insom
Feb 7, 2010 08:58 PM
