64/98-394cui distributor???
I need a new vacuum can and some spring to play with for my motor, are the distributor the same as other Olds big blocks??
I noticed that the 394 isnt mentioned.....
I am looking at this kit
http://www.summitracing.com/parts/crn-99601-1/reviews
As Joe said, the distributors are different. The vacuum advance units are also different. The original equipment vacuum advance units for your engine are available. Finding the "performance" kits for the older engines will be significantly more difficult. In the old days even dual breakers were a possibility. Try the used market.
The connecting rods use the same center-to-center distance and rod bearing diameter as those on the 425 and early (short stroke) 400 motors. They do not "interchange" without work. I don't know if the small end bore or width are the same. Balance will be different.
Pretty much. The old school way to do this is to weld the slot in the point plate and file it to the limit you want. Use a distributor machine, or a timing light with a vacuum pump, or a protractor.
chris83
Aug 18, 2012 01:47 PM
