4GC Vaccum Question
Just pull the hose off and connect a vacuum gauge. If there is no vacuum at idle but it goes up as you start to open the throttle, it's ported. If it is high at idle, it's manifold vacuum.
You can do this same test by holding your finger over the hole.
