455 water pump
455 water pump
i noticed a small leak coming from the weep hole on the bottom of my water pump so i decided to change it out .it looks to be the original so i would like to try and rebuild it for future use .anyone know where to get a rebuild kit for this pump ?and is that an original part number?thanks
I don't know what that number is, but I can get it to cross reference to a water pump that matches.
http://www.oreillyauto.com/site/c/de...itemDetailTab_
just an update (and gripe i guess) changed out the water pump last night after work ,which is a fairly easy project one would think.couldnt use my original fan bolts because they are a fine thread ,and the new pump took course thread .that required a trip to the hardware store.once everything was finished i started to fill with antifreeze and noticed a leak coming out of the edge of the pump housing.turns out the supplied gasket wasnt getting full coverage at one point of the housing .btw this was a tru flow pump from napa (they didnt have the ac delco in stock and i didnt want to wait)to make a long story short i made my own gasket out of some gasket material i had and redid the whole thing .decided to let things sit overnight before filling.looking back i should have paid more attention to the fit before installing ,lesson learned .
Nor Cal Andy
March 29th, 2012 07:27 PM
