455 valve cover - PCV valve?
Old Jun 28, 2017 | 06:15 PM
Eastflorida's Avatar
OK, last question for the night... I promise!!
Found an open hole in the passenger sider valve cover. Don't know how I or many others missed it. I'm assuming this is for a PCV valve plumbed to the air cleaner?
Is so, what do I need to pick up locally to fix? There is a hole on the air cleaner on that side as well...
I know, stupid Newbie posting like crazy tonight!!! LOL
Thanks for any help...
Old Jun 28, 2017 | 06:21 PM
Yes one side is for a PCV and the other would have a line going to the air cleaner.
Old Jun 28, 2017 | 06:25 PM
It appears the driver side goes to the carb, so is that the PCV? If so, what do I put on the passenger side to the air cleaner, just a hose? Sorry for being ignorant on this, but thanks, for the help!
Old Jun 28, 2017 | 06:59 PM
RetroRanger's Avatar
72 Olds CS
yes drvrs side has the PCV pass side would have a breahter w line to the aircleaner or some just use a pop in breather like this
Old Jun 29, 2017 | 04:49 AM
The stock PCV system is somewhat elaborate with special metal tubes for the breather side... Depends on what you want.
Old Jun 29, 2017 | 08:48 AM
You can get a factory style breather at your local auto parts store - this pic is from the AutoZone web site. The parts store replacements may be plastic whereas the factory originals were metal, but they look and function the same.
Old Jun 29, 2017 | 12:53 PM
Note that the OP has aftermarket chrome valve covers which may or may not accept a factory-style breather. The grommet in the second photo is not the D-shaped Olds grommet, so we don't know what size the hole is.
Old Jun 29, 2017 | 01:43 PM
Good point. The OP can just put a PCV in the passenger side and an open breather in the drivers side. Or he can install a breather with a nipple and connect a hose to the air cleaner assy.
Almond900
Feb 26, 2016 02:56 AM
tgilligan
Mar 22, 2013 01:35 PM
jpc647
Oct 12, 2012 03:11 PM
sborruso
Aug 24, 2009 07:13 PM
