455 trouble--please help--
Guys,
I really need some help here. I bought a 455 for my cutlass. I started taking it apart to get it to the machine shop. The problem I have is that I noticed a hole behind the upper timing gear. It looks very round, almost like it should be there. The problem is that it is very jagged to the touch. I don't think it should be there. I can see right into the valley from the front of the block. Does anyone know if that hole should be there? Any pics of the front timing area--preferably disassembled-- would be GREATLY appreciated. I don't want to waste any more time or money on this engine if it shouldn't be there.
I think your fine. Here's a couple photos showing a hole with rough casting edges about the 1:30 o'clock position above the camshaft. John
Heres a before picture.....Unmodified
Rounded and smoothed out....
The little stuff like this helps the somewhat weak Olds oiling system.....
Smoothed out the drain back path from the heads also...
No prob........the block in my pictures is now stuffed full of Eagle Rods Arias flatop pistons and a lightned crank.......I'll get my Eledebrock heads ready this winter and have her all ready for spring!
