455 trouble--please help--
Old Dec 20, 2009 | 02:34 PM
FIJIBLUE72's Avatar
Guys,
I really need some help here. I bought a 455 for my cutlass. I started taking it apart to get it to the machine shop. The problem I have is that I noticed a hole behind the upper timing gear. It looks very round, almost like it should be there. The problem is that it is very jagged to the touch. I don't think it should be there. I can see right into the valley from the front of the block. Does anyone know if that hole should be there? Any pics of the front timing area--preferably disassembled-- would be GREATLY appreciated. I don't want to waste any more time or money on this engine if it shouldn't be there.
Old Dec 20, 2009 | 02:47 PM
2blu442's Avatar
I think your fine. Here's a couple photos showing a hole with rough casting edges about the 1:30 o'clock position above the camshaft. John
Old Dec 20, 2009 | 02:50 PM
steve walker's Avatar
swat455
if its on the upper right side its the top end oil drain for the valve train just looked at mine grind it down so its smooth and so oil wont puddle up there
Old Dec 20, 2009 | 03:13 PM
BIGJERR's Avatar
I bleed Oldsmobile
Oil drain back to the pan........I round mine out even more and taper the hole to insure qiuck drain back to the pan......I got a pick somewere hold on........
Old Dec 20, 2009 | 03:17 PM
BIGJERR's Avatar
I bleed Oldsmobile
Heres a before picture.....Unmodified
Rounded and smoothed out....
The little stuff like this helps the somewhat weak Olds oiling system.....
Smoothed out the drain back path from the heads also...
Old Dec 20, 2009 | 05:24 PM
FIJIBLUE72's Avatar
You guys are AWESOME!!!! Thank you.. I was really scared about that!
Old Dec 20, 2009 | 05:51 PM
BIGJERR's Avatar
I bleed Oldsmobile
No prob........the block in my pictures is now stuffed full of Eagle Rods Arias flatop pistons and a lightned crank.......I'll get my Eledebrock heads ready this winter and have her all ready for spring!
aquabird
Oct 2, 2013 10:34 PM
1BOSS83
Jul 21, 2013 10:28 AM
borneagain 77
Jul 11, 2013 01:11 PM
MN71W30
Mar 28, 2010 11:07 AM
drtdobber
Feb 14, 2007 01:16 PM
