455 stroker
Old Nov 4, 2013 | 12:28 PM
mcutlass1969's Avatar
455 stroker
Gang
has anyone built a 455 stroker? If so can i get in detail the parts you put into it from the crank to the top end?
Old Nov 4, 2013 | 04:19 PM
61reoldsman's Avatar
What size of motor are you wanting ?.Contact Mark (Cutlassefi) ,he's done quite a few of them ,he can tell ya what parts you'll need.
Old Nov 4, 2013 | 04:42 PM
Kyle's 77 Cutlass's Avatar
Cutlassefi is the man to see about these. He is building me one soon
Old Nov 4, 2013 | 05:05 PM
cutlassefi's Avatar
Geez thanks guys, you're making me blush!!
Actually I figured I'd let a few of the guys on here respond. There are a couple that just recently did them.
But the general info is that you can either buy an Eagle stroker crank or have an "N" crank offset ground to a 4.500 stroke. Both cranks, the Eagle and the stocker, will use 7.1" BBC rods in that configuration. Mahle and CP make pistons.
You'll need to relieve the block in certain areas for rod clearance. Good heads are a must, hardly seems worth doing if it can't breathe. And depending on the hp level at least strapped mains, maybe even a girdle. Remember you're swinging a bigger arm (stroke), that's harder on everything.
The intake and carb will depend on the rest of the equipment and desired power.
Hope this helps.
Mark
Old Nov 4, 2013 | 05:57 PM
gregvm's Avatar
Contact Bill Trovato at BTR performance in Rochester NY (585-303-7560), let him know what your goals are and he'll give you an honest evaluation of what you need.
Old Nov 4, 2013 | 05:59 PM
brandon 455's Avatar
Can you give me a round about price on what doing this would cost.
Ive been wanting to do this as well.
Old Nov 5, 2013 | 04:00 AM
cutlassefi's Avatar
I'm thought I just did that. I guess not.
I think the Eagle rotating assembly kits are about $2200.00. Again from there your choice of cam, intake, carb and headwork will depend on how much power you're looking for and desired results. And both the Mahle and CP pistons are only available in one dish size each.
However as in any quality rebuild, first rate machine work and attention to detail will go a long way.
Old Nov 5, 2013 | 05:17 AM
If ya have ta ask ya can't afford it laddie !lol
Old Nov 5, 2013 | 11:54 AM
Trust me I can afford one
Old Nov 5, 2013 | 12:12 PM
Well thats a good start for sure .
Old Nov 5, 2013 | 12:25 PM
oldsmobiledave's Avatar
Fyi
Too general a question with not enough info provided to expect a reasonable price estimate.
For example what heads?, iron or aluminum? & what level of porting?.
What intake & carb?
Roller cam?, hydraulic?, solid?; solid roller
What compression ratio & whose pistons based on what stroke & bore.
What crank?
Budget at least $10K if you have some of the parts already. Budget up to $18K if you have absolutely nothing & want it built to the max plus installed & chassis tuned.
By the way...You'll still need to budget for an upgraded fuel system to feed the monster & an upgraded trans & differential to deliver the power to the ground.
TORTUS
Oct 18, 2012 04:50 AM
smietana
Jan 15, 2012 08:35 PM
Wilson
Nov 22, 2011 04:52 AM
85olds442
Feb 3, 2010 12:03 PM
442 Jack
May 23, 2008 11:16 PM
