455 rocker arm stud
Old January 25th, 2015, 07:49 PM
cwb442's Avatar
455 rocker arm stud
I was just wondering. I'm running comp cam roller tip rockers. The studs I have are 5/16 stud in the head then transition to a 3/8 stud on the rocker side. Curious as to how much risk is there in breaking one on a motor with 450ish hp and under 5500rpm?
cwb442 is offline
Old January 26th, 2015, 05:10 AM
cutlassefi's Avatar
Not much at that rpm with the right spring pressures. Amount of hp is pretty insignificant.
cutlassefi is offline
Old January 26th, 2015, 05:13 PM
cwb442's Avatar
Thanks mark
cwb442 is offline
1966Oldsmobile
August 4th, 2014 04:41 AM
EightballZ
March 24th, 2014 05:03 PM
rcdynamic88
November 12th, 2013 01:50 PM
oldzy
June 1st, 2011 08:30 PM
defiant1
March 19th, 2011 07:14 AM
Quick Reply: 455 rocker arm stud
