455 olds back pressure
Old Aug 2, 2025 | 04:02 PM
79cut's Avatar
When I turn off the engine sometimes
it sounds like it wants to start again type thing and a swoosh sound
doesn’t happen all the time
any ideas what this could be
Old Aug 2, 2025 | 04:23 PM
old80cs's Avatar
Idle at too high, timing too far advanced?
Old Aug 2, 2025 | 04:40 PM
79cut's Avatar
timing is dead on
idle could be. Around 1100 rpm but settles out at 900
Old Aug 2, 2025 | 04:54 PM
Originally Posted by 79cut
timing is dead on
Idle should be around 600 RPM in drive, assuming this is an automatic transmission. I am just guessing since you gave us very little information.
Old Aug 2, 2025 | 04:56 PM
79cut's Avatar
Idle should be around 600 RPM in drive.
that’s to low imo
I want good water flow and oil pressure
mine is a built 455 4 speed
Old Aug 2, 2025 | 05:12 PM
69CSHC's Avatar
Sounds like minor run on... how is the gas quality ?
Old Aug 2, 2025 | 05:14 PM
79cut's Avatar
not sure. I put 93 octane gas
Old Aug 2, 2025 | 05:31 PM
that’s to low imo
Depending upon the year, the manual transmission idle speed spec is 650-750 RPM for a factory engine. Your modified engine may need different parameters than a factory engine.
What is your present idle speed and ignition advance?
Old Aug 2, 2025 | 05:35 PM
79cut's Avatar
idle speed is 900-1100
total timing is 34 degrees
idle timing 12-14
Old Aug 2, 2025 | 05:51 PM
So when you turn the key off, you get some run-on, a.k.a. dieseling?
Old Aug 2, 2025 | 06:23 PM
79cut's Avatar
yes. I would say 1 out of 10 times
actually never heard of that term run on
But I’m assuming that’s what it is
Old Aug 2, 2025 | 06:33 PM
OLDSter Ralph's Avatar
that’s to low imo
idle timing 12-14
Define "built 455".
Is the engine idling smooth at 1100 RPM's or still loping ? How much oil pressure are you trying to maintain ?.
Old Aug 2, 2025 | 06:37 PM
1100 RPM sounds like way too high an idle speed and is likely the source of your problem. What are your cam specs?
Old Aug 2, 2025 | 06:38 PM
79cut's Avatar
Define "built 455".
Build is all your goodies
cam pistons 30 over etc
motor idles fine in any range
i just like to run it at 800-1000 rpm
oil pressure is good 35-70
Old Aug 2, 2025 | 06:39 PM
79cut's Avatar
not sure. I would have to look
Old Aug 2, 2025 | 06:42 PM
That’s about the most generic, non-informative post I have seen in a while. My engine has an aftermarket cam and .030” over pistons, too.
Please provide accurate, specific information so we can actually help you.
What are your cam specs? Which .030 over pistons? What carburetor? What distributor, and what timing parameters?
Old Aug 2, 2025 | 06:45 PM
79cut's Avatar
I mean what would be the difference what cam or pistons I’m running ?
would high performance parts cause this more than stock ?
Old Aug 2, 2025 | 06:46 PM
79cut's Avatar
What are your cam specs? Which .030 over pistons? What carburetor? What distributor, and what specs?
let’s assume I have a stock 455
Old Aug 2, 2025 | 06:49 PM
Wow. Yes, a long duration cam and high compression pistons would be very different that a factory short duration cam and low compression pistons. Details are important.
Old Aug 2, 2025 | 06:50 PM
Then set the idle speed to stock settings. Don’t try to out-think the design engineers.
Old Aug 2, 2025 | 06:56 PM
69CSHC's Avatar
Run on / dieseling is much like it sounds. As if the engine never shuts off or keeps trying to restart even though you already shut it down with key in hand. My 67 had it bad once with low octane gas, went on for a few seconds... horrible, the engine is jumping, convulsing, and sputtering.
You have a very minor version of it.
This very short video should match you to a T. And the 3 comments posted should seal the deal for you, which includes the solution.
Old Aug 2, 2025 | 07:03 PM
79cut's Avatar
https://youtube.com/shorts/JImxGbYFj...p0icYK5c0vqqza
thanks. Interesting
Old Aug 2, 2025 | 07:15 PM
Define "built 455".
Sounds like you spent money on "goodies" that you have knowledge of their function. High performance parts can make a difference. Your preference to run the idle at 800-1,000 RPMS has little merit if it idles smooth in any range.
You have a 455 with "grocery getter" parts. "Grocery getter" is defined as a car that you run errands and get groceries with.
I have a 455 with a big cam that will smooth out between 1,500 and 2,000 RPMS. I have it idling about 1,000 RPMs.
YOUR idle is way too high, thats your problem. You don't need 35 PSI oil pressure at idle.
Old Aug 2, 2025 | 07:16 PM
Just back off the idle speed. Since you don't know your cam specs, try 750-800 RPM in neutral. I'm willing to bet that'll solve your problem.
Don't worry about oil pressure. Anything over 10 PSI at idle will be adequate.
Old Aug 2, 2025 | 07:18 PM
79cut's Avatar
it did it at 600 rpm as well
I bought it like this
I didn’t build it
Old Aug 2, 2025 | 07:25 PM
79cut's Avatar
here’s my specs
Old Aug 2, 2025 | 07:26 PM
79cut's Avatar
Old Aug 2, 2025 | 07:27 PM
I didn’t build it
Try what Bangscreech suggested.
Old Aug 2, 2025 | 07:40 PM
Do you have an HEI distributor ?
Old Aug 2, 2025 | 07:41 PM
79cut's Avatar
yes
Old Aug 2, 2025 | 07:45 PM
  #31
69CSHC's Avatar
Ralph it's my understanding that oftentimes built engines are mistimed to an engines base information. And this often leads to disappointment in performance till the modified timing is achieved ?
Old Aug 2, 2025 | 07:53 PM
  #32
I never suggested re-timing the engine. I did ask about an HEI distributor which often times has higher initial advance. Idle speed smoothness he said was fine in any range.
Old Aug 2, 2025 | 09:01 PM
  #33
Ok, so, your idle is too high. If you MUST have that idle, you need an idle stop solenoid.
My car is messed up some, but my curb idle in drive is 650 and the park idle is 1000. It will diesel. The quadrajet has holes for a solenoid that mounts on the front left of the carb, and lines up with a tab on the throttle bracket. When powered, this solenoid extends. These can also be used for AC on idle boosting. The idea is that you set the slow idle screw to something like 500. Do that with the solenoid unplugged. Plug the solenoid in, and adjust its stud (it has flats like a bolt, screw it in or out) to get the idle you want. Wire this to ignition on power source. When you turn the key off, the ignition stops, but now, also, the idle drops from 1000 to 500. This closes down most all fuel, and allows the engine to shut off nicely. I shut my car off 15 times last week, and I may have got one or two extra firings out of all of them. Highly recommended.
Old Aug 2, 2025 | 10:45 PM
  #34
You said this, then posted build sheets showing a 230 degree duration camshaft. That is a long ways away from a stock 455.
It’s hard to give helpful recommendations if you don’t give us accurate information.
Old Aug 2, 2025 | 11:11 PM
  #35
79cut's Avatar
any reason why it would run off per say ? Either cam ?
Old Aug 3, 2025 | 08:53 AM
  #36
Not sure what you're asking here, but in general a big cam (and yes, your cam is a long way from factory) necessitates a higher idle speed, leading to increased risk of post-ignition. If a high idle speed is required or desired -- for whatever reason -- maybe look into an idle stop solenoid, as @Koda suggested.
Old Aug 3, 2025 | 08:59 AM
  #37
Either all that, or just shut it off in gear and let it stall itself.
Old Aug 3, 2025 | 10:18 AM
  #38
79cut's Avatar
thanks.
Old Aug 3, 2025 | 10:34 AM
  #39
steff70's Avatar
Hi all,
before having rebuilt my 425 in my 1966 Starfire, I also experienced sometimes dieseling when shutting off. I checked the idle timing and it was fine. Then I checked the distributor advance weights and found out the advance mechanism was stuck (vacuum advance was okay though).
I pulled the distributor and made everything move nicely again, and for some months I had no dieseling any more. So you could check the rpm advance weights if they work and allow timing to be advancing at higher rpm. Because if not, timing seems good at idle but is too late at higher rpm (means, typical driving condition), and then heat up spark plug tips and other parts too much so that they might cause the dieseling effect.
In my case, unfortunately the problem came back after some months and I had to repeat the procedure. When I overhauled my engine last winter, I finally found the root cause (probably not very common, but still I want to share here):
My engine was not well maintained by the previous owners, had lots of oil sludge and completely broken valve stem umbrella seal fragments sitting everywhere. When I teared down the engine and checked all oil gallery's and plugs, I found that a small fragment of a valve stem seal made it even past oil plump and oil filter into the oil plug which should drain oil onto the camshaft/distributor gear in the back of the engine block. So the distributor including its advance mechanism did not get oiled properly and got stuck over time.
Ah, another possibility which also happened to me was that the harmonic balancers outer ring slipped due to a defective rubber layer (see the two pics at the end of my post). So the timing seemed right but actually was not! I first tried to add a mark to the right place on the outer ring but it kept moving. I finally fixed the issue buying a new balancer from damperdudes.com, can recommend them really. Fast service and excellent quality.
Just my 5 cents, maybe could also be explanations for your case.
CU, Steffen
Here I add some pics for illustration:
Advance weights before restoration, no wonder theat the mechanism did not work smoothly
Advance weights before restoration, no surprise that the mechanism did not work smoothly
After cleanup
After cleanup
Valve stem seal fragments in my engine like crazy
They even clogged the oil holes down from the heads
Crazy amount pulled out from the engine
Crazy amount of valve stem seal fragments pulled out from the engine
Clogged oil hole for distributor gear
Minor oil flow was still possible, but in no way as intended
Removed the fragment
Location of the plug, looking down into the block at the distributor flange
The plug is behind the sheet metal plug on the left
Second possibility: timing wrong even though Mark seems right
Second possibility: timing wrong even though mark seems right
My balancer rubber was defect and the outer ring slipped
Old Aug 3, 2025 | 10:40 AM
  #40
79cut's Avatar
Originally Posted by steff70
Hi all,
My engine was not well maintained by the previous owners, had lots of oil sludge and completely broken valve stem umbrella seal fragments sitting everywhere. When I teared down the engine and checked all oil gallery's and plugs, I found that a small fragment of a valve stem seal made it even past oil plump and oil folter into the oil plug whit should drain oil onto the camshaft/distributor gear in the back of the engine block. So the distributor including its advance mechanism did not get oiled properly and got stuck over time.
Just my 5 cents, maybe could also be an explanation for your case.
CU, Steffen
thanks for the info
