455 J Head upgrade
Old Mar 12, 2017 | 03:04 AM
Goldenhand's Avatar
455 J Head upgrade
Hi everybody!
I have a -76 455 cutlass with J heads and only want to wake it up a little bit.
If I change the cam, intake manifold and put on a KN-filter what will it do to the engine in hp/torque?
I´ll keep the original carburator, exhaust manifold but make it with dual pipes.
And at last can somebody please tell what cam and intake I should use, i´ve tried to serch the fourm but I can´t find a set up.
Regards
Mattias from Sweden
Old Mar 12, 2017 | 06:18 AM
brownbomber77's Avatar
The heads are the thing holding that motor back. I wouldn't do anything else until the heads are fixed.
Old Mar 12, 2017 | 07:54 AM
Kennybill's Avatar
I agree that the J heads are the "bottle neck" that will hold the engine back. The J heads combustion chamber is a little bit larger than the previous years heads plus they are restrictive. If the short block is in good condition, I would find a nice set of rebuilt G, Ga, C, K, Ka, E heads either small or large valved. A small RV (torque cam) Comp Cam has a couple. This way you can keep your factory bridges and rockers. Buy matched valve springs. Keep your factory intake, unless you want to put a Edelbrock Preformer. New timing set. The small increase in compression, less restrictive heads and the camshaft &springs with fresh timing set will make your engine think it's on steroids, ha ha but true. I have a similar setup but with headers (Comp Cam 0.456/0.456 lift) in my convertible and it's pretty frisky. JMO. That's about the cheapest best cost upgrade and still very drivable. Good luck.
Old Mar 12, 2017 | 08:14 AM
deadeyejedi's Avatar
i just did everything kennybill suggested to my 76 455 ,im still in the test and tune stage ,but i can tell you its a whole new animal .
Old Mar 12, 2017 | 11:56 AM
Goldenhand's Avatar
Thanks for all answers.
It might be the way for me to do that or I just got an offer for a 455 jet boat so maybe I buy it and switch it.
bigred1972
Dec 14, 2015 09:00 PM
young olds
Jun 3, 2014 08:13 PM
Olds Scott
May 29, 2013 08:15 PM
Ragtopw1972
Oct 18, 2012 08:19 AM
CLcutlass
Aug 21, 2011 06:25 PM
