455 into a 1967 '888?
Old Dec 11, 2017 | 07:05 AM
Dolores's Avatar
455 into a 1967 '88?
I have the engine pulled from my 88 and it needs some machine work and stuff - it could run me a few $. As an alternative, I see quite a few 455's for sale, are they a straight drop into a 1967? (I'm concerned really with engine mount location and tranny hookup).
Andy
Old Dec 11, 2017 | 07:42 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Well, a "888", it that similar to a "666", the number of the beast? But seriously yes, it is a direct bolt in place of the 425.
Old Dec 11, 2017 | 08:36 AM
Dolores's Avatar
Ha ha- wow it looked fine when I posted it, definitely finger trouble.
Thanks for the info
Old Dec 11, 2017 | 08:51 AM
The 425 and 455 are externally identical. I recently dropped a 455 into my 67 D88 in place of the 425. The only difference is the crankshaft flange bolt pattern. You'll need to use a 1968-1990 flexplate in stead of the one on the 425. Transfer everything else to the 455 - starter, exhaust manifolds, water pump, accessory brackets and pulleys, etc. I also swapped the oil fill tube and intake manifold for optical reasons. This is not necessary but I wanted mine to look like the original 425.
Note that you may want to swap the 67 intake onto the 425 to allow you to retain the original carb and throttle linkage. The 68-up cars used a cable throttle and the carb fitting is different. Also the choke is different. You can swap to a later model carb and intake but you'll need to do some fabrication on the throttle linkage and the kickdown switch may not work as a result. This is why I kept the original intake.
Mikes442
Drivetrain/Differentials
Jan 31, 2014 03:57 AM
Ken'sConvertible
Aug 5, 2012 07:43 PM
2blu442
Ninety-Eight
Apr 25, 2007 09:20 PM
Retrorocket88
Mar 1, 2007 06:22 AM
mjscutlass
Nov 29, 2006 06:18 AM
