455 Intake Manifold comparison
Old June 3rd, 2013, 09:47 AM
  #161
1968ragtop's Avatar
I'll try bring this post back to what the thread was originally about. Sorry for the hi jacking. Was just wondering if a torquer would work decent on a mildly built motor. I'm thinking it will loose bottom end (but still be decent) and gain lots in the mid range and top end hp.
1968ragtop is offline
Old June 3rd, 2013, 09:50 AM
  #162
Mr. Johnson
rjohnson442's Avatar
subscribed can't wait for the results. I'm most curious about the open vs 4 hole spacer will preform on the preformer. Just ordered a open phenolic spacer for a dual plane.
rjohnson442 is offline
Old November 13th, 2013, 09:11 AM
  #163
brownbomber77's Avatar
Was there a final result on the Torker yet? Just curious, piecing my 455 build together now...
brownbomber77 is offline
Old March 3rd, 2014, 08:05 PM
  #164
1977 C-10's Avatar
Am looking for an street intake for a mild 455. How did the test results shape up to be?
1977 C-10 is offline
Old March 4th, 2014, 04:26 AM
  #165
cutlassefi's Avatar
For a mild build the Performer would be my #1 choice.
cutlassefi is offline
Old March 4th, 2014, 09:32 AM
  #166
1977 C-10's Avatar
Who has a good used one on hand? This Torker tends to be a intake suited for .550-up lift cam stall/3.50 gears ect?
Old March 4th, 2014, 04:09 PM
  #167
cutlassefi's Avatar
Cam lift has very little influence on manifold choice. It's the gear, use and duration that dictates that.
Old March 4th, 2014, 04:25 PM
  #168
drjr56's Avatar
cutlassefi...would there be a benefit using a Torker with a roller hyd.236/244@.050 duration a 400turbo trans with 2200 stall and 3.73 rear gears.It's a 455 with Mondello heads.I have a performer with the divider cut on it now.Looking for stronger mid and upper but not over 6200 rpms. And will I lose much from 1000 to 3000 rpms. Thanks..and what do you think about that cone in the plenum.It's a streeter 95% of the time.
drjr56 is offline
Old March 4th, 2014, 04:48 PM
  #169
1977 C-10's Avatar
Cam is Voodoo 262/268 gear shall be 3.20-3.50 series. 3500+lb vehicle. What is the minimum power/combo to utilize the Torker in basic street/mild applications? When does it become nessicary to up grade from in the standard dual planes?
Old March 4th, 2014, 06:55 PM
  #170
cutlassefi's Avatar
You need way more cam than that to justify a Torker.
I'd shoot for 500hp as the turning point. It's already been proven over and over, an out of the box RPM will make 500 on the right combo without issue.
Old March 4th, 2014, 07:40 PM
  #171
1977 C-10's Avatar
Right. These guidelines are evasive to find in research. What are the order of dual planes that go from bone stock to mild cam/duals/slight stall? Only the Edelbrock Performer? Too bad there has not been a thread to end all threads that will give a hardcore guideline of what works up to that ragged edge of drag motor. Massive tourque is what I am going to shoot for in each motor. This one is very mild. The next will have forged +30, E-heads, larger cam. Street & interstate is the goal. A 150hp nitrous will go on to bump the deal for that 1/4 mile blast. Earlville is only 24 miles away. All concrete.
Old March 4th, 2014, 07:43 PM
  #172
1977 C-10's Avatar
Who re-curves HEI's for these motors?
boese1978
December 17th, 2013 11:20 AM
MDchanic
Paint
30
July 7th, 2012 10:07 AM
Aceshigh
March 11th, 2012 02:12 PM
Del70
October 11th, 2010 01:05 PM
My442
Brakes/Hydraulic Systems
April 1st, 2009 01:18 PM
Quick Reply: 455 Intake Manifold comparison
