455 ID help
Hi I sent my son to look at a motor for me today. It has "G" heads and a non EGR intake manifold that is stamped 455. The seller said it was a 71. When he got home he said the block looked like it was a faded gold color. OhOh 350. Any way I need help cause I can't pick it up until Sunday.
Will Big block heads fit on a small block?
Will a big block intake fit on a small block?
Thanks PIT 1969 442 convert
The easiest way to ID an Olds big block is to look at the casting number between the oil fill tube and oil pressure switch/sender. 400 reads 396026 G , and 455 reads 396021 F. Heads will fit, intake will not (big block is wider).
G heads are 71 455 heads block color is meaningless as a lot of time hass passed since it was new. There should be an F on the casting inback of the water pump top on the block to the right of the oil fill tube.....that will be the sure 455 ID.
Correct .The thing is I won't be able to check the casting until Sunday.That is why I asked about the heads and intake being interchangable. My curiosity is driving me crazy. Thanks Pit 442 convert
Unfortunately paint is not a tell all. 455's are about 1 1/2 inches wider than the 350's at the intake. Look to the right of base of the oil fill tube, behind the timing cover, the block should have a casting number There should be a "F" in the casting numbers for a 70-72. Some 72's and then throught 76 had a "Fa" and "L" were marine or motorhome motors. 350's were 2, 3a, 3b, and 5s
The 455 heads will fit on the 350 the intake will not. and if the intake says 455 then its probably a 455 someone probably painted it gold to trick people into thinking its a small block.
Ha, nice catch, had to post on this cause i also got my 455 for $100. Ga headed 72', and another $30 later a nice set of used 69' pistons/rods to go with it. Looking forward to the rebuild ^_^ What are your plans with this one?
Still building my 69 442 . However the only motor I had at that time was a 72-76 Fa block, low compression and J heads. I did manage to find a set of nice C heads a couple of years ago so I'll use those on the 68 motor. That should wake up the neighborhood.
Pit 69 442 convert
Pit 69 442 convert
Well I finally started to dismantle some of the 455. They are Ga heads not G. Also the motor is froze up. Number 1 cylinder has some rust ,it looks like the rings only but not sure. I filled all the cylinders with transmission fluid, now I wait. Here's a question though, on the rod caps they are all stamped accordingly #1 to 8. Did Oldsmobile do this during production or has somebody opened up this engine previous. Happy new year Pit
Thanks, I will use some , it doesn't look bad really. as of today. I measured the depth of the dish and it's .150. I'll take some pics and post. This will be interesting if not anything else. Pit
455
Well here's some pics. The first is #1 cylinder .I think this is the culprit. The other piston is what the rest look like. It doesn't look bad but I still can't move it.
Any suggestions?
Any suggestions?
Here's a couple more. I'm going to the Detroit swap meet tomorrow so I'll get back to work on it tomorrow night . PIT
This is what I have , It does seem to high.
Bore 4.180
Stroke 4.250
Cylinder head volume 80cc
Effective dome volume +.150
deck clearance .030
compressed gasket thickness .039
Any help is appreciated PIT
Bore 4.180
Stroke 4.250
deck clearance .030
And is that in cc's?
15cc's would be a reasonable dish for a big block (40, 37, and 15 are standard big block dish volumes), but 0.15cc's would be essentially a flat top, which you don't have.
If you made an error, then I'd bet your compression is a lot less than that first calculation showed.
It turns out only one piston was froze and it looks as if the rings did no cylinder wall damage. Until I tear the whole engine down I really won't know for sure. Also there will be no more boring. .060 is enough. I'll have to use my Fa block instead. Sure would be nice to have a casting correct block though. I'll post pics as I go . Thanks again for all your help boys PIT
hello everyone, not trying to high jack your thread. i just wanted to ask a question about my block's Id and didn't want to start i new thread, i found the vin derivative.I can only make out a few numbers and don't know what they mean anyway
,here is a pic thanks for any help
I cropped the image and played with it a bit. Looks like you have an Olds 455 from 75 production. Definitely Lansing motor as designated by the M. Your VIN derivative is mostly in shadows. Looks like it might be 394479?
blockid.jpg?t=1328902473
sx455raidercelticfan
Nov 23, 2010 05:45 AM
SKINNY IL
May 14, 2010 07:12 AM
