455 Hydraulic Roller Tappet Noise - Please Help
Old Nov 22, 2015 | 02:32 PM
69442's Avatar
I have a 455 engine that was built a couple of years ago, but after pulling my frame to paint it and add aftermarket front & rear suspension, then reassembly, the engine only has about 100 miles on it. I have developed a top end lifter / rocker arm type noise. The engine specs are as follows:
1970 455 bored .030, balanced Olds forged crankshaft w/ Eagle connecting rods, Icon 10.5-1 forged pistons, Comp Cams hydraulic roller camshaft XR290HR w/ Comp Cams roller tappets, correct length pushrods, Edelbrock RPM aluminum heads (out of the box) w/ upgraded valve springs for hydraulic roller cam, Harland Sharp 1.6 roller rocker arms, Edelbrock RPM Air Gap intake manifold, Mallory electric fuel pump, Holley 850 carb, Aftermarket 2.5" W/Z exhaust manifolds.
I adjusted the rocker arms 1/2 turns, (3) different times to no avail. Comp Cams warrantied the tappets and replaced them with a newer design. I have adjusted the new ones 1/2, 3/4 & 1 full turn, again to no avail.....
It sounds like I have a couple noisy lifters on each side of the engine. Any help or advice would be greatly appreciated!
Thanks, Bob
Old Nov 22, 2015 | 02:37 PM
cutlassefi's Avatar
Yes ditch the Comp lifters, they suck. Check around, you'll find lots of people have had trouble with both Pontiac and Olds roller lifters from Comp.
Old Nov 23, 2015 | 04:27 AM
69442's Avatar
Yes ditch the Comp lifters, they suck. Check around, you'll find lots of people gave had trouble with both Pontiac and Olds roller lifters from Comp.
Cutlassefi,
What brand hydraulic roller lifters do you recommend?
Bob
Old Nov 23, 2015 | 05:43 AM
cutlassefi's Avatar
Howards, Lunati or Erson. All of those are made by Morel. I sell them for $365.00 to your door but you're welcome to look around as well.
Also make sure you don't have any retainer to rocker or rocker to pushrod interference.
bluecab
Sep 14, 2021 07:52 AM
RROLDSX
Mar 8, 2013 05:50 PM
VinMichael
Apr 4, 2012 07:10 PM
fly1
Dec 8, 2010 07:07 PM
442garage
Oct 20, 2008 10:25 AM
