455 Head Gasket Blocking Water Jackets???
Old Jul 1, 2017 | 01:56 PM
gbledsoe3's Avatar
I'm using Mr Gasket Ultra Seal #5981. I'm new to this but is this right where some water ports are completely blocked and others are partially blocked? All of the water jackets at the top are completely blocked.
Old Jul 1, 2017 | 03:28 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
They are supposed to be that way. I thought the Ultraseal's were white, look exactly like the Rocket Racing head gaskets I bought, except their head gaskets are .028" vs .038".
Old Jul 2, 2017 | 04:19 AM
The openings in the block are large to allow the casting core sand to be removed. They are too large for correct cooling flow, thus the smaller holes in the gasket. Keep in mind that coolant flows rearward in the block, up to the head, then forward in the head. If the forward holes were too large, the coolant would take the path of least resistance (like a short circuit) from the block up to the head and the rear cylinders wouldn't get cooled.
Rilmar
Jul 20, 2021 08:10 AM
stratoblues
Nov 15, 2014 12:17 PM
KQQLCAT
Jan 11, 2011 09:43 AM
captjim
Sep 23, 2008 05:21 AM
blonzz
Sep 27, 2004 10:54 AM
