455 exhaust manifold sheet metal
Old May 8, 2015 | 11:09 AM
Bitburger's Avatar
I am installing a 455 in my 69 vert using W and Z manifolds for dual exhaust. Do I need to use the heat deflector sheet metal around the manifolds and around the starter ?
Any input would be much appreciated
Old May 8, 2015 | 02:43 PM
442Harv's Avatar
Do you have them? If so, why would you not want to use them?
Old May 9, 2015 | 05:50 PM
Bitburger's Avatar
I do have the shield for the starter. I also have a shield from a T manifold which looks like it lines up pretty well for the passenger side .
Is there more to gain by installing the shield on the passenger side than just the heat riser ?
I have read on here about starting issues related to heat build up from not using the starter shield.
Will a stock starter shield from a 350 will work on a 455 ? And can it be bolted up just by removing the starter ?
BTW the motor is in the car with the manifolds bolted up
hilbily
Body work
Sep 9, 2014 08:54 PM
OldsMotion
Oct 10, 2009 10:19 PM
corvus5469
Aug 11, 2009 06:24 PM
Jody Karls
Jul 21, 2008 11:45 AM
tmbrennan
Jul 19, 2008 09:29 AM
