455 engine qiestion
Old May 7, 2010 | 05:48 PM
Phil Glass's Avatar
455 engine qiestion
I have a 455 in my car, Aluminum intake W-455 part number 406115, Head casting number E, engine casting number by the power steering bracket is 30M332__6, the last 3 numbers are hard to read, any ideas what year this engine is, Thanks Phil from Milwaukee 72, 442
Old May 7, 2010 | 06:12 PM
67Olds442X2's Avatar
Navy P-3 FE (Ret.)
It's a 1970 block.
3"0"M332_6
Old May 7, 2010 | 10:02 PM
And it has '70 442 heads 'E'.
Old May 7, 2010 | 10:13 PM
svnt442's Avatar
What makes them 442 heads? All 455 heads except W30 heads were E castings in 1970. The only way to tell if they MIGHT have been on a 442 would be to check the size of the valves, and even that is not 100% as all Toroandos got the large valve heads.
Old May 7, 2010 | 10:41 PM
Yup, you're right, brain fart on my end.
Old May 7, 2010 | 11:17 PM
svnt442's Avatar
No biggie. Just don't want to confuse the guy.
Old May 8, 2010 | 05:20 PM
Phil Glass's Avatar
Thanks for the help, any one know if the Rochester had stud or bolts to holsd it to the Aluminum W-455 intake, just took off the Holley, and has 4 stud which do no fit the Rochester, also anyone ahve a diagram of where the vacuum lines go, thanks Phil
Old May 9, 2010 | 12:44 PM
The Qjet uses bolts - long ones in the front and short ones in the back.
805cut
May 3, 2012 08:11 PM
Olds luvr
Mar 17, 2010 06:57 PM
njot33
Sep 25, 2009 09:07 AM
pinky
Oct 1, 2007 11:24 AM
