455 dipstick
Old Oct 1, 2009 | 12:05 PM
suppressivefire's Avatar
455 dipstick
I bought a 455 chrome dipstick on ebay for my 72 455 what should be the correct length? ive seen a couple different numbers also if not what is the oil capicity on a 72 455 does the year matter for the length or capacity?
thanks
chris
Old Oct 1, 2009 | 12:40 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
If I remember correctly the measurement should be 4.5 inches from the flange above the barbs to the add line.
Old Oct 1, 2009 | 02:30 PM
thanks
chris
With stock pan and filter it's 5 qts. The easy solution here is drain the oil, change the filter, fill with five quarts, run the engine briefly (to fill the new filter), let cool, then check the level on the new dipstick. Scribe a new mark as necessary.
Old Oct 2, 2009 | 06:25 AM
You can also sand the dipstick and paint it white so the oil contrasts with the dipstick. It makes it easier to see your oil level.
Old Oct 2, 2009 | 09:58 AM
Now when I recieved the tube and dipstick there was nothing with it is there supposed to be an O ring? When I set it in the block its very loose any tips?
thanks for all the help!
Old Oct 2, 2009 | 10:29 AM
I got a Mr. Gasket chrome dipstick for my 455. It didn't come with a gasket but it fit snug. I had to tap it in with a small hammer.
Old Oct 3, 2009 | 05:58 PM
There is no gasket. The dipstick tube must be pressed into the block. If it is very loose, then I suspect you have not hammered it down into the block. The formed ring on the tube mus sit against the boss on the block.
Old Oct 25, 2009 | 09:51 AM
therobski's Avatar
Or go to a Chevy store and order part number #417091 guide $19.67 goes into the block and part number #10110440 dip stick $18.40 your set.
Old Oct 26, 2009 | 06:07 PM
There is 3 ring/ bumps on the block, the first bottom one easily slides in the block the second seems possibly a hair bigger than the enging block's hole then the top ring which im guessing is the formed ring your talking about.
Old Oct 29, 2009 | 04:15 PM
so im guessing just take a hammer and screwdriver to it?
dantecl
Oct 27, 2013 02:50 PM
Jolly Green
Jan 16, 2013 05:07 PM
zodiacblueS
Sep 2, 2011 04:01 PM
1964F85
Aug 7, 2010 07:25 PM
tim72
May 13, 2009 05:03 PM
