455 compression
Old Sep 18, 2011 | 04:18 AM
my442conv's Avatar
455 compression
a 1970 442 455 engine rebuilt about 12000 miles / 7 yrs ago bored out .030, competition cam.
I'm about to start a chassis off restoration, and I'm not intending to rebuild the engine, so I just did a compression test and all cylinders are about 110-118. I'm thinking of just pulling the heads, new valves, roller rockers P rods,seats & hone the heads..........I'm thinking that will be fine.
I think the compression is good ............any ideas?
J
Old Sep 18, 2011 | 05:00 AM
Why would you do all that to a 12,000 mile engine?
Old Sep 18, 2011 | 06:14 AM
cutlassefi's Avatar
And someone obviously put in the deep dish pistons, 110 is low for a "70" 455.
Old Sep 18, 2011 | 06:59 AM
my442conv's Avatar
what would be the normal compression on a 455? and at 110 on compression would i benefit greatly if i just rebuilt the entire engine?
Old Sep 18, 2011 | 07:03 AM
my442conv's Avatar
Eric,
I am pulling the engine, trans to start a chassis of restoration, and i don't know much about the engine, other then what i was told.......so I need to know more before i put the engine back in the car.
J
Old Sep 18, 2011 | 07:20 AM
cutlassefi's Avatar
All I can tell you is I have 9.7:1 with a smallish Hyd roller and I have 175psi.
How does the car run? If it runs o.k. then leave it alone. If you're wanting more performance then it might be helpful to pull one head, that way you can see what piston is in it etc.
Eric - you and I both know that just because it was "rebuilt" unfortunately doesn't necessarily mean it was done correctly.
Jmo.
Old Sep 18, 2011 | 12:13 PM
Originally Posted by my442conv
... i don't know much about the engine, other then what i was told.......so I need to know more before i put the engine back in the car.
Ahhhhhhhh... Exploratory surgery. I understand. You didn't mention that you weren't the one who "rebuilt" it .
Old Sep 18, 2011 | 01:31 PM
my442conv's Avatar
no......It was rebuild about 2004, 2 previous owners before me.......not sure what was put in the engine..................but i guess I'm going to find out soon enough.
J
greenslade
Mar 29, 2011 03:56 PM
455cutlass
Oct 27, 2010 08:24 PM
dgreen
Mar 26, 2010 10:19 AM
0590trab
Mar 29, 2009 06:47 AM
