455 block?
455 block?
I need help on how to find out what block I have and I also need to get it bored out and machined due to rust in the cylinders. I was wondering what all to bore it to and so on?
Im wondering what the original specs of the block and was wondering when I do get it cleaned up and bored if there is a certain measurement. Im only trying to restore it not make it into some monster machine yet
The Chassis Service Manual has all the critical dimensions and tolerances for your engine (and everything else on the car). A 455 block can be bored 0.060" over easily, though you only want to go the minimum necessary to clean up the cylinders.
The earlier 68-72 blocks have thicker cylinder walls,and can be bored easily to +0.060,and still have good thickness,or could be bored even more.The later smogger blocks,as I call them,don't have as much thickness,and I would try to stay at +0.030 with those.A +0.060 overbore on those will generally make them thin,which will result in slightly hotter running temps.
A thicker cylinder wall will also aid in ring sealing.
ut442
March 9th, 2012 11:57 AM
gearheads78
February 29th, 2012 08:11 PM
