455 block?
Old Jan 13, 2011 | 01:24 AM
foo's Avatar
foo
455 block?
I need help on how to find out what block I have and I also need to get it bored out and machined due to rust in the cylinders. I was wondering what all to bore it to and so on?
Old Jan 13, 2011 | 05:03 AM
cutlassefi's Avatar
A little more info would be helpful, intentions, location etc.
Old Jan 13, 2011 | 04:17 PM
import extermination's Avatar
casting numbers are located on the ledge above the water pump. or look at the number beside spark plug #1
Old Jan 13, 2011 | 04:45 PM
507OLDS's Avatar
396021F is the casting number for ALL 455 blocks.They also had 396021Fa blocks from 73-76.
Old Jan 13, 2011 | 11:20 PM
foo's Avatar
foo
Im wondering what the original specs of the block and was wondering when I do get it cleaned up and bored if there is a certain measurement. Im only trying to restore it not make it into some monster machine yet
Old Jan 14, 2011 | 06:12 AM
The Chassis Service Manual has all the critical dimensions and tolerances for your engine (and everything else on the car). A 455 block can be bored 0.060" over easily, though you only want to go the minimum necessary to clean up the cylinders.
Old Jan 14, 2011 | 02:18 PM
red&blue442's Avatar
What is the difference between an F and an Fa block, other than the years?
Old Jan 14, 2011 | 06:40 PM
foo's Avatar
foo
Any idea where I could find one of these manuals?
Old Jan 14, 2011 | 07:10 PM
You could always start here...
Old Jan 15, 2011 | 05:57 AM
507OLDS's Avatar
The earlier 68-72 blocks have thicker cylinder walls,and can be bored easily to +0.060,and still have good thickness,or could be bored even more.The later smogger blocks,as I call them,don't have as much thickness,and I would try to stay at +0.030 with those.A +0.060 overbore on those will generally make them thin,which will result in slightly hotter running temps.
A thicker cylinder wall will also aid in ring sealing.
bocoogto
Aug 26, 2023 06:09 PM
TicTocTach
Jun 16, 2015 04:03 PM
gearheads78
Feb 29, 2012 08:11 PM
NEWOLDSMAN
Nov 17, 2009 12:19 PM
