455 bbo
Old May 12, 2025 | 06:22 AM
  #41
69CSHC's Avatar
Originally Posted by 72cutlass408
Checked fluids, turned crank with a standard length 1/2” ratchet. I’m pretty happy with it so far
Nice !
Congratulations on picking up one of Oldsmobiles best. If she lead a charmed life she just needs a freshening up...
Carburetor checks out, post #3 from Joe Padavano, here https://classicoldsmobile.com/forums...-442-a-140028/
And the heads are correct and the best.
Old May 12, 2025 | 06:32 AM
  #42
If C heads are the best, why did Olds handicap the W30 cars with different heads? Were they afraid of making too much power?
Old May 12, 2025 | 10:41 AM
  #43
Sugar Bear's Avatar
It even has an original hose clamp on the water outlet...you may have hit a grand slam! Step cautiously, slowly and don't hesitate to ask our advice. Don't throw any parts such as alternators, starter, carburetor or distributor away and stay organized. Those engiwnes were beasts in stock format.
That is a premium fuel only high compression engine.
Old May 12, 2025 | 03:31 PM
  #44
69CSHC's Avatar
Point taken.
Yeah I think he scored !
The lowly 225 hp 455 I had could absolutely rip in the 4 door tank it came in. I can only imagine how sweet a hi comp 68 will feel in an A body.
Old May 12, 2025 | 03:42 PM
  #45
Sugar Bear's Avatar
"Yeah I think he scored !"
Wait until he finds a steel crank in it...!
Old May 12, 2025 | 06:38 PM
  #46
72cutlass408's Avatar
Thank you everyone for the great support. I’m just about done with restoring my 69 4 speed car. It has a great running 350, 2 barrel carburetor in it now. I’m thinking about 2 months, I will start the engine tear down. I will make sure to save everything.
I’m in California, any recommendations for a good “Oldsmobile” machine shop
Old May 12, 2025 | 08:07 PM
  #47
Sugar Bear's Avatar
What are your plans? Asking about "the tear down", it may not need one unless you don't want stock. If you want stock get it running, do a compression test and see what you have. Remember you'll have significantly more HP and torque than a stock 442 with a 400G engine with the 455 in its stock rendition. Have you rebuilt engines before specifically Olds engines?
Did the 350/2V swap to a '69 455/4v and a fresh TH350 in a '69 Cutlass two door post w/AC many decades ago, even stayed with single exhaust due to financial constraints and the performance increase was B I G !
Old May 13, 2025 | 10:55 AM
  #48
Do a compression test first. Send heads out for inspection. Hopefully crank is already drilled but if not will need to do that. Reseal, new freeze plugs etc. I will only replace what is necessary, keep it mostly original.
Old May 13, 2025 | 01:35 PM
  #49
Sugar Bear's Avatar
If compression is good you could leave them in place and replace the valve seals only. If the heads are removed you'll lose some compression due to thicker replacement head gaskets vs the factory steel shim gaskets.
Old May 13, 2025 | 01:41 PM
  #50
Mill the heads the equivalent of the difference in gasket thickness, then everything is back to where it was originally.
Old May 13, 2025 | 02:16 PM
  #51
Yes will compensate for gasket thickness
Old May 13, 2025 | 05:45 PM
  #52
Sugar Bear's Avatar
Excellent advice Matt, just didn't think of it at the moment...doh. Thanks!
Old May 24, 2025 | 07:54 AM
  #53
I spoke to Bernard Mondello, I think I will be getting a set of heads built by him.
Old May 25, 2025 | 07:01 AM
  #54
cutlassefi's Avatar
Jan 27, 2025 09:06 AM
Bullwinkle
Jun 1, 2023 05:01 PM
gearheads78
Feb 16, 2023 03:12 PM
Proteegolf
Jul 22, 2022 05:26 AM
