455 all stock wanting to upgrade
Old Mar 9, 2020 | 04:54 PM
MJMascioli's Avatar
Hi,
Do you think buying the edelbrock complete top end kit is good It includes heads,intake manifold, cam is a good way to go then buy those those Thornton headers and edelbrock 750 carb any thoughts
mike
Old Mar 10, 2020 | 09:56 AM
jensenracing77's Avatar
I am not an expert engine builder but from my experience, an engine build is an entire package or you are tossing money away. I would not throw that much money into a top end without rebuilding the bottom to match. Trying to add power to a 50+ year old bottom end is not a good idea in my opinion.
Old Mar 10, 2020 | 10:14 AM
droptopron's Avatar
delete
More details on your build/goals would help. Others will opine, but I've heard that the cam in that kit is an old style grind. You can do better than that.
Old Mar 10, 2020 | 11:30 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Also get something besides the Edelbrock carb. Either a Street Demon 750 or Quickfuel 750+ vacuum secondary.
Old Mar 10, 2020 | 06:33 PM
My vote would be keep your existing carb, install a manifold, and use a more modern camshaft. The edelbrock cams are very outdated. Unless they have modified their cam grinds profile to keep up with the airflow of their heads, your going to be disappointed. Talk to Mark about a custom cam.
if the engine is sound (good compression, good oil pressure, and acceptable leak down) bolting on some go fast stuff won’t hurt anything. If the engine is tired, why bother?
Old Mar 10, 2020 | 08:32 PM
OLDSter Ralph's Avatar
my vote would be keep your existing carb, install a manifold, and use a more modern camshaft. The edelbrock cams are very outdated. Unless they have modified their cam grinds profile to keep up with the airflow of their heads, your going to be disappointed. Talk to mark about a custom cam.
If the engine is sound (good compression, good oil pressure, and acceptable leak down) bolting on some go fast stuff won’t hurt anything. If the engine is tired, why bother?
x 2.
Olds1971
Apr 25, 2022 02:32 PM
Odmark
Mar 8, 2013 09:54 AM
Prsabordo
Apr 14, 2010 04:57 AM
Prsabordo
Apr 13, 2010 05:02 AM
scr boi
Mar 12, 2007 04:40 PM
