450 HP/TQ 455--Carb Question: Holley 950 HP--down leg or annual boosters?
Carb Question for my mild .060 455 build. Edelbrock 2151 Performer Intake, .500 lift cam to be chosen. 3.23 posi, TH400, Stock G heads to be changed to Edelbrock Aluminum Performer box stock heads in future
Can someone enlighten us on the distinction between down leg boosters versus annular boosters on a Holley Carb. Looking at 950 HP Holley.
Thanks.
Thanks.
Down leg boosters are just that, angle down word. They typically effect throttle response etc. Your best bet would be to buy a Quick Fuel 850. Either the black diamond or the super Street series.
Thank you for your input guys. Please explain why you are partial to the Quick Fuel 850 Black Diamond or Super Street? I keep hearing about the Quick Fuel Carbs...
On the surface they look like dressed up Holleys. No?
No, QF's have replaceable air bleeds, both high and low speed, replaceable power valve circuits, three different rates in which to operate the secondaries and so on. They're not your basic Holley.
what would be the difference between SS and diamond Q-series? just choke and vac secondaries?
lets say BD-850 and BDQ-850...looks like they differ in jetting
Here we go again...
I know I am being redundant Mark, so thanks for your patience.
For my stop light to stop light, freeway cruiser 455 convertible, 450 TQ, you would buy the 850 Super Street Quick Fuel--out of the box carb, over an out of the box Holley 950 HP?
Let me add to the equation a bit--I am a lousy carb tuner. I really need to bolt it on, set the idle, max mixture screws, and have a carb that won't bog like i just threw a can of carb cleaner down the throat when I light em up.
Maybe I am asking too much. If the Quick Fuel Super Street 850 gets me there easier, I am in. Also...
I need a cam, lifters, timing gears too. We talked about this before. Hydraulic, flat tappet. Iron G heads. Stock. Rebuilt. Springs closed installed height 110lbs@1.720 inches. Open 280 lbs @1.250 inches. Coil bind at 1.145 inches. Hooker 3202's, Edel 2151, TH400, Posi 3.23's. Credit card ready...
And I need a distributor. Don't really want to run an MSD box. I have an old Olds HEI I was going to have upgraded. What's the ticket here?
Again, thanks for your help again.
I think they need a 800 or 850 cfm for these larger motors. The 750 cfm might be borderline from what 455+ Olds motors seem to want. Otherwise, there is a ton of good feedback on these. I must resist the urge of throwing dual 625's Street Demon on an Offy intake.
Now, if you factor in also the fact this is for street with a mild cam, without trick heads and not all out race....
I don't really subscribe to the too big or too small theory, within limits. The carb ratings, in some ways are rather meaningless on airflow, since any rise or fall in vac changes it flow. Or one reason to rate the 2 barrels, at a slightly higher vacuum giving much higher air flow and almost doubling the cfms, if needed and on demand.
I have run 1050 3 barrels, and currently have a 900 CFM Holley injection system, and had 3 CFM sizes I could have ordered on it, at the same general price. I ordered the 900 because I knew it would be the favorite, if I went to sell it, and knew it wouldn't be too big. I also have the 750 Street Demon to replace the injection, if it gives me anymore problems like frying the ancient Holley CPU again. Just saying
Actually the big Thermoquad is 850 cfm or more with mods. The later Qjets are 800 cfm or more with mods, that's what mine is. No denying the Street Demon is a great carb but about as small as someone should go even with a street 455, I hope they make one more size. I would much rather see everyone buy the Street Demon and enjoy their cars instead of buying an Edelbrock and having another thread on how terrible their car runs.
http://www.v8buick.com/showthread.ph...900-thermoquad
http://www.thecarburetorshop.com/Car...arburetors.htm
http://www.pontiaczone.com/forum/showthread.php?t=30099
DW's 455 is running 11s, with a 750 QJet. The Chevy L78s and other 500+ horsepower BBC ran 780 Holleys to obtain those number, with only headers added.
Then I have seen 350 Olds class cars running low 12 high 11s, with the two barrel Holleys early 70s. No ported heads, or roller cams, or big CFM carb or MSD.
I think the 750 Street Demon is plenty for what he has and 99% of the other Olds. I wouldn't be afraid of losing anything important with the 625. I think some with them might even pop off the hair pin clip on the secondary linkage, and see how fast it runs just on the smaller primaries alone.
As far as more CFMs from the ones that offered from what I see it looks like as easy change, to bore the primaries out even more, and put larger throttle blades in it, but there is probably no gain there in ET. I doubt Holley would cut its own throat, with an even larger one.
The smallest Demon shooter is bigger than what the standard ones Edelbrock is using I think, but they will sell you bigger ones LOL That and the float setting is causing most of the grief I think on them. That, and the inability to change the secondary air flow.
My point is the the street Demon is cheaper, with advantages such as metering rods for tuning and won't be such a problem under hot hoods, with the plastic bowls.
Now, what if they were heat rejecting white, instead of black, would they run even cooler. Now where did I put my rattle can LOL The carb he got looks like a fine carb.
oldspackrat
September 10th, 2012 06:20 AM
