425 rod and bearing
Old Feb 26, 2024 | 05:59 AM
Jetmek's Avatar
425 rod and bearing
Can someone tell if the purpose of this oil passage and if it necessary? Squirt hole goes thru across parting line. The new bearings dont have the cut out like originals. Thanks.
Old Feb 26, 2024 | 09:43 AM
The oil spit hole lubricates the cam lobes.
Old Feb 26, 2024 | 09:58 AM
Jetmek's Avatar
guess ill be breaking out the wizz wheel to notch new bearings
Old Feb 26, 2024 | 10:08 AM
Not sure I'd go that far. Olds stopped using the spit holes at some point.
Old Feb 26, 2024 | 03:16 PM
cutlassefi's Avatar
Old Feb 26, 2024 | 04:55 PM
BillK's Avatar
Like the others said Olds and Pontiac both had them but did away with them in later years. For what its worth I always heard that they were to lube the cylinder walls not the camshaft. Dont know if that is true or not.
yellowrocket
Jun 19, 2025 06:44 PM
PaulWinn
Nov 5, 2023 06:52 AM
Torofan67
May 19, 2022 09:58 PM
Amarion58
Mar 21, 2017 12:57 PM
Fastbrianman
Sep 11, 2011 07:22 PM
