400ci Oil Pan Removal
Yes, but you might still have to loosen a motor mount/raise the engine and have the crank throws in the right position.
Some folks would also say just pull the engine.
You have to think of the other things too, when you do this. MAW's
Once again, the SEARCH function is your friend:
https://classicoldsmobile.com/forums...n-removal.html
https://classicoldsmobile.com/forums...-pan-swap.html
https://classicoldsmobile.com/forums...d-oil-pan.html
https://classicoldsmobile.com/forums...an-gasket.html
