400 g block build with pics
Old Jun 10, 2014 | 07:20 AM
  #121
cutlassefi's Avatar
Originally Posted by Smitty275
1 7/8 is the correct size. At 1 3/4 you'd have been choking it off.
X2, you'll make the low end torque anyway, The 1 7/8 will help make more hp all the way thru the rpm range.
Old Jun 10, 2014 | 07:50 AM
  #122
Bernhard's Avatar
Nice
Old Jun 10, 2014 | 08:48 AM
  #123
TripDeuces's Avatar
Just found this thread. Sorry to hear bout your problems but on a positive note that is one beautiful Olds. Stunning really. You can tell your attention to detail is pretty high.
I have to agree with the others here about the port job. He just took a cartridge roll and knocked off the roughness on the cylinder walls. Not that that's a bad thing but I'm not sure that qualifies as a 'full porting job'. Those are some beefy looking headers. Can't wait to see the results from those.
Old Jun 10, 2014 | 06:19 PM
  #124
ralsy's Avatar
Thanks everyone. Its nice to receive support and advice.
Old Jun 12, 2014 | 11:34 PM
  #125
ralsy's Avatar
Headers have arrived back from ceramic coaters and are installed.
Old Jun 12, 2014 | 11:36 PM
  #126
ralsy's Avatar
More photos
Old Jun 13, 2014 | 05:03 AM
  #127
442rocketdave's Avatar
She should be running good now!! Good looking set of headers and a nice installation!
Old Jun 13, 2014 | 10:17 PM
  #128
ralsy's Avatar
They are definitely sweet.
Old Jun 14, 2014 | 03:36 AM
  #129
Stevec's Avatar
How were they to install? did they need any massaging to fit?
Old Jun 14, 2014 | 07:13 AM
  #130
cutlassefi's Avatar
I believe they'll make a significant difference. Remember to check the air/fuels. I'll bet the carb will need rejetting.
Old Jun 14, 2014 | 07:29 AM
  #131
Bernhard's Avatar
Look forward to hearing positive results
Old Jun 15, 2014 | 02:37 AM
  #132
ralsy's Avatar
No massaging as they were custom made. Picking up the car tomorrow so ill let you know how it goes. Next pit stop is carby tuning.
Old Jun 26, 2014 | 10:06 PM
  #133
ralsy's Avatar
I took the old girl to the mechanics today for the carby tune up after the headers were installed. Good news! He says that he has tuned it and it is produsing 340 hp rw compared to 226 hp rw when it was last dynoed. Now in the scale of muscle cars it might not seem like much HP but 100 HP more than last time. Im happy. I pick the car up on Monday and will post a copy of the dyno results.
Old Jun 26, 2014 | 11:29 PM
  #134
ralsy's Avatar
One more thing. The mob that did the dyno tune on the olds blocked off the vacuum advance, saying it is only really there to help with fuel economy at light throttle and with my cam its not needed. Is this correct?
Old Jun 27, 2014 | 12:41 AM
  #135
ralsy's Avatar
Also, he said that I really need a bigger carby (800 - 850 cfm). He has apparently set idle a little rich and told me that I needed to take it for a "hard" good drive every now and then to clean the plugs.?????? I'm happy that I have received over 100 extra horses but at what cost?
Old Jun 27, 2014 | 03:10 AM
  #136
Bernhard's Avatar
Nice
Know that is good news 114 hp increase
Enjoy
Old Jun 27, 2014 | 03:50 AM
  #137
Smitty275's Avatar
Engine Builder
Glad to hear your moving forward in a positive way.
Now go hook up the vacuum advance to a straight manifold vacuum source. You'll have to slow the idle back down after you hook it up. The difference in fuel economy under normal driving is substantial and performance wise there is absolutely no difference. If you experience pinging under light throttle you may have to adjust the vacuum can on the distributer a little to take a little out if it.
Old Jun 27, 2014 | 04:58 AM
  #138
cutlassefi's Avatar
Great news!
I'd hook it up to spark ported vacuum first and see how it feels. I'm not a fan of hooking it up to manifold vacuum because for part of the advance curve your mechanical and vacuum advance will be working against each other.
You can always get an adjustable vacuum advance and fine tune it from there.
Did you ask him why he set the idle on the fat side? That doesn't make much sense to me unless he's trying to mask another issue.
Best of luck!!!
Old Jun 27, 2014 | 05:52 AM
  #139
Ralph 340 at the wheels is very respectable and I am glad you have made great progress! Sounds like its getting there! on the issue of running it richer i suspect the carb may not be the right one for the job but your in the ballpark now!
Old Jun 27, 2014 | 08:19 AM
  #140
Bernhard's Avatar
You can have a Q jet built for your engine its more than just adjusting the carb.
All the Qjet body's are not the same,even though they look very similar.
I would contact someone like Dean Oliver that know these carbs very well.
What are you running for a distributor and are you running a ignition box like a MSD multi spark box.
Take the car out and enjoy it
There should be more in it with Q jet built for the engine and a sorted ignition system and timing curve.
Old Jun 27, 2014 | 12:39 PM
  #141
ralsy's Avatar
Running a HEI distributor no ignition box. I have a Moroso adjustable Vacuum advance unit which I will install when I get the car back. I will have more information on Monday. I also purchased a Quadrajet performance tuning kit with a selection of jets, rods, hangers, high flow needle and seat, etc, which the mechanic was given. Thanks for the feed back guys. I can see the finish line and it seems I am getting my second wind
TicTocTach
Jun 16, 2015 04:03 PM
stonecad
Feb 11, 2014 02:02 PM
chrisneu68olds
Dec 30, 2011 10:17 AM
1969w3155
Jun 14, 2011 10:12 PM
