400 CID how much Oil?
Old Apr 12, 2020 | 03:38 PM
Billyaxe's Avatar
I just did my first oil change on my 68 442. The dip stick was reading low before I started. I drained out 9 quarts and the filter.
I put on 7 quarts and get no reading on the dip stick.
could this actually take 9 or 10 quarts? I don’t know if it was overfilled when I got it and maybe it’s the wrong dip stick.
Could the
pan be a racing (more capacity) pan? This car came from 1/4 mile racer Bob Voss with a 4.66 gear in it, so aftermarket racing parts are likely.
here’s a picture of the pan. Hoping for advice before I over fill. Thanks —Billy
Old Apr 12, 2020 | 05:49 PM
gs72's Avatar
72Cutlass S
that is definitely not a stock pan. Nine quarts is probably normal for that pan.
Old Apr 13, 2020 | 04:42 AM
Seems like if you drained out 9 qts and the filter, you would have to put back in 9 qts and the filter. 91/2 quarts? That sure is a big pan! Badass looking headers too!
Old Apr 13, 2020 | 05:21 AM
Run to Rund's Avatar
Conventional thinking is that one benefit of a big pan is that you an lower the oil level from the crank for less windage. Eight quarts should be more than sufficient.
Old Apr 13, 2020 | 05:26 AM
Billyaxe's Avatar
Thanks. Just afraid I’ll overfill it. —Billy
Old Jun 18, 2020 | 06:41 AM
Billyaxe's Avatar
Here is a better picture of this custom oil pan. Problem is that the installer left the 21 1/2 inch stick dipstick so I’m not getting a reading even on 9 quarts. Eventually I’ll change to a stock pan. It’s bugging me not knowing what level I’m at. —Billy
Old Jun 19, 2020 | 02:51 PM
android 211's Avatar
Maybe the next time you change the oil you could use a scope to see where is the pickup? Its probably down near the bottom but don't count on it.
Old Jun 19, 2020 | 04:17 PM
v8al's Avatar
Registered Olds Owner
You should be able to do some very rough calculations based on measuring the bottom section of the pan to calculate the capacity.
A web site like this might help out: https://www.sensorsone.com/length-wi...me-calculator/
Knowing the pickup location would be excellent information. If it's positioned correctly at the very bottom of the pan then as long as you don't over fill it 9 quarts should be good. You might have to build your own dipstick though.
I notice the ram air scoop in the last photo - nice!
yellowrocket
Sep 1, 2019 06:42 AM
george landis
Aug 16, 2019 03:26 PM
kansjfr
Aug 17, 2015 10:23 AM
oldsman71-69
Jun 14, 2015 07:44 PM
bobbyb
Oct 24, 2010 09:44 AM
