394ci cylinder heads
Old December 8th, 2010, 11:28 AM
gringocordoba's Avatar
Hi friends, I bought an Oldsmobile Holiday Super 88 coupe 394ci here in Argentina, and I want to restore it the better I can.
The engine wasn t working so I removed it and I noted that the 2 cylinder heads are broken.
The numbers are gm 1- 195 -577808 and gm 2-203-577808 and 1 of them has the number of the engine in it.
Did you have this parts? I need to buy them.
I found a rocket 324 cylinder heads from an older olds but they didn t seem similar at the exhaust, is the only thing that is not the same?
Sorry for my english.
PS: is a rebild kit for engine restoration available? piston, rings, etc
gringocordoba is offline
Old December 8th, 2010, 11:56 AM
the crankshaft is the same from older rocket engines with the 394? and the crankshaft bearings?
Old December 8th, 2010, 12:04 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
www.rossracingengines.com
Here you will find everything you need.
J-(Chicago) is offline
Old December 8th, 2010, 12:51 PM
citcapp's Avatar
Welcome to CO
http://www.kanter.com/p20-oln.html for engine rebuild kits
You'll have to find used heads
citcapp is offline
Old December 8th, 2010, 08:05 PM
59-59-59's Avatar
Assuming that the heads are cracked, where the cracks are located, and where you are located ( Argentina), it might be easier and a whole lot cheaper to have the cracks professionally welded and machined at a competent machine shop. Parts are relatively easy to find for a rebuild
59-59-59 is offline
Old December 10th, 2010, 04:17 PM
http://cgi.ebay.com/ebaymotors/Oldsm...#ht_2303wt_893
cheaper than kanter.
but what about quality?
Old December 10th, 2010, 04:25 PM
http://falconglobal.biz/
do you know if they are good?
Old December 10th, 2010, 04:31 PM
citcapp's Avatar
I would contact Falcon and ask who the manufacture is. Falcon is a parts place and cheaper seldom means better
citcapp is offline
Kaline
April 18th, 2022 03:35 PM
5998DownUnder
December 27th, 2013 09:12 PM
gringocordoba
February 3rd, 2011 10:18 AM
sssingo
November 12th, 2008 09:25 PM
Kaline
March 23rd, 2008 06:53 AM
Quick Reply: 394ci cylinder heads
