394 oil spitting out breather
Old Dec 20, 2008 | 07:47 AM
f-85's Avatar
Ive asked a few friends and cant get a good answer. The car keeps spitting oil out the breater. I dont beat on the car, but i also dont baby it. I beat on my F-85, and i baby my dog. This car is for driving. Why would it be spitting oil out the breather?
Josh
Old Dec 20, 2008 | 09:56 AM
rocketraider's Avatar
Oldsdruid
Apparently no one has told you that 394's are notorious for blowby problems after they get some miles on them. The problem is aggravated by their need for true high-octane fuel.
Just for grins, if the engine still has the mushroom-shaped oil filler/breather cap, make sure the foam element is in place. If not, some of that foam you use to seal up a window airconditioner can be cut to fit and work fine. Make sure you oil it and squeeze it out damp before you put it in there.
Old Dec 20, 2008 | 10:17 AM
f-85's Avatar
Hey Rocketraider
Nope didnt get the memo. LOL It does have the old style breather cap. It has some net type stuff in it. Ill pull the car back in the garage and take a look.
Josh
Old Dec 20, 2008 | 11:23 AM
f-85's Avatar
Is this the one your talking about?
Old Dec 23, 2008 | 03:37 PM
Oldsdruid
That's actually an aftermarket service part and probably better than the original design, which actually had a piece of foam rubber inside the mushroom which would rot out after a while. Meaning- no filter for the crankcase vent system, and the blowby would collect under the cap and drip all over everything.
Try washing that breather in kerosene and oiling it, or if you can find the parts, convert it to a closed PCV system.
But I've never seen a 371/394 that didn't have some blowby. Long as it's not using a lot of oil, I learned to live with it.
These engines are also known to have valve guide problems and if the valve seals are trash (I can guarantee they are), that will aggravate it. Then the pieces of valve seal plug up the drainback holes, oil collects in the valve covers and gets sucked in past the valve guides. I had one Starfire engine years ago that I tripled its oil mileage (from 500 miles/qt to 1500, which I could live with) simply by rodding out the drainbacks and installing new valve seals.
Old Dec 23, 2008 | 03:46 PM
44TEETWO's Avatar
I have one that shoots the trans fluid out the dip stick tube. The trans works fine but throws fluid? I have been told that the vent behind the bell housing is plugged. I don't want to drop the trans but..........
Old Dec 23, 2008 | 05:05 PM
f-85's Avatar
Hey Rocketraider
Thanks for the tips. When i get a chance ill pop off the valve covers. And ill also clean out the breather.
Thanks Josh
Yukon
Mar 3, 2014 10:36 PM
FrankElTanke
Apr 12, 2013 07:15 AM
Dool Cat
Sep 28, 2012 11:13 AM
mauls
Jun 30, 2010 10:47 PM
85LS
32
Aug 17, 2009 08:19 PM
