394 fans
Old Apr 2, 2014 | 08:51 PM
64 Oldsmobile's Avatar
394 fans
Hello. Not been able to work on my 1964 Olds super 88 for awhile. and I know this question has been asked before I am sure. I have three fans 1- is the 4 blade and 1 is a 5 blade clutch fan and the last 1 is a 6 blade clutch fan. I was wondering what one would be best to run on my 394 with A/C. Thank You!
Old Apr 2, 2014 | 09:08 PM
I would run the 6 blade if it fits in the shroud properly.
Old Apr 2, 2014 | 09:18 PM
That's was what I was checking. I thought the 4 blade was for a non A/C if I was thinking right. It's always good to ask someone else. Thank You!
Old Apr 5, 2014 | 07:28 PM
63super88's Avatar
i have a 5 blade fan on mine, should be same 394 and practically same radiator/shroud. mines pretty old and the little dust cover for the clutch bearing area came loose but i stuffed it with a little lithium grease so it works for now. it keeps the car pretty cool for the time ive been using it, which is almost all the time. even in the summer, unless the a/c wa crankin in traffic for 20 min climbed a little. i was pretty good with coolant leaks until this sudden issue i developed just 2 days ago which has me a little stumped. 6 bladed fan would be cool, maybe ebay has one let us know if the 6 blade fits maybe ill look into it for mine i use it pretty often, maybe get mine ready for summer if i plug this strange leak. thanks and good luck man.
Old Apr 5, 2014 | 07:41 PM
I will try to keep you posted. Good Luck on yours.
Wyze
Sep 10, 2010 01:07 PM
oldspartsgirls
Jul 14, 2009 07:16 AM
koolbreeze21
Jul 13, 2009 05:12 AM
chris83
Jun 13, 2009 08:16 PM
oldjunk
May 1, 2009 03:10 AM
