394 engine has small miss - need advice
Old Jan 19, 2014 | 07:20 PM
  #41
Curious to see if the points correct the misfire.
Old Jan 21, 2014 | 06:46 PM
  #42
aikmanolds's Avatar
there is a pretty good piece about engine skipping in GM cars by a guy who had a lot of related experience, he explains it it detail...page 80 under "readers respond" in the March 2014 issue of Hemming's Classic Car, FYI. Doug
Old Jan 22, 2014 | 10:44 AM
  #43
fv64olds98's Avatar
Hello All,
I am planning to install the points and condenser back on the car this weekend. Do you guys know if the Pertronix Coil can be used with standard points. I am just concerned because the Petronix coild is supposed to generate 40,000 volts.
Old Jan 22, 2014 | 01:17 PM
  #44
I don't see a problem with it, but you need to make sure your resistor wire is installed or an aftermarket ballast resistor in series with the coil power wire.
Old Jan 22, 2014 | 01:24 PM
  #45
frankr442's Avatar
The points just serve as a trigger for the coil. The 40,000 volts don't run thru them, just the coil wire to the distributor.
Old Feb 5, 2017 | 02:33 PM
  #46
Brungul's Avatar
Hi! Trying to wake this thread back from the dead. Did you find out what was causing the problem? I am having the same problem only that it is on cylinder 5 on My -64 394 engine.
Sorry for the poor english I'm swedish so i don't know better.
Regards Whobbert
Old Feb 5, 2017 | 05:24 PM
  #47
aikmanolds's Avatar
Just curious, have you run a compression check on that (and other) cylinder?
Old Feb 5, 2017 | 11:52 PM
  #48
Brungul's Avatar
Aye! The engine is resently rebuilt ANT the compression test shows less then 1% in deviation. I have bin rebuilding the carb 14 Times' trying out new gaskets and flott levers now with the missfire still on number 5. So i got tired Of this carb and just tested a edelbrock 750 and the engine rund like a dream. So that is why i was curios what happend to the starter of the threads engine.
Old Feb 6, 2017 | 05:27 AM
  #49
aikmanolds's Avatar
interesting. I had a similar issue on a much older (1952) model, fixed it by switching carbs. I attributed it to a vacuum leak.
ah7910
Oct 21, 2014 06:58 PM
63super88
Aug 19, 2013 10:07 AM
Thomas Simcich
Jul 23, 2010 09:30 AM
Holiday55
Dec 6, 2007 04:06 AM
